General Tab
The General tab is for editing the basic attributes of the template.
Template – General Tab
Name
The name should be unique and descriptive. The system displays it for templates in the list on the Templates Interface.
Description
The description is optional but recommended. Because you can scope each policy narrowly or broadly, the name combined with the description should clearly explain what objects and events it monitors or blocks, where in the network it looks, and when it activates. The system displays the description for templates in the list on the Templates Interface.
All changes made to a template must be saved before leaving the configuration interface.
Tags​
Tags are enabled as an organizational tool for templates only. Many preconfigured templates have tags that let you quickly find the template you want through various groupings. Tags don't create a duplicate template, but rather display the template in different folders under the TAGS node. Multiple tags can be identified for a template with a comma-separated list. New tags can be created, which create a new folder under the TAGS node. Use the right-click Refresh option on the TAGS node in the Navigation pane to display new tags and/or display template-tag modifications. See the Tags Node topic for additional information.
History​
The system automatically populates history details in the center of the General tab when you create or modify a template.
Policy - General tab > History section
It shows who created the template (Added by), when the template was created (Added on), who made the latest modification (Modified by), and when that modification occurred (Modified on).
Schedule​
Use the schedule to set the time period for an enabled policy to monitor or block events.
IconLabelRepresents
alwaysactivebuttonAlways ActiveIndicates the policy will be active at all times when enabled. This is the default setting
specifictimesbuttonActive at Specified TimesIndicates the policy will be active only at the specified times when enabled. There are two options for setting the specified times:
  • Local Server Time – Schedule is set according to the local server’s time
  • UTC Time – Schedule is set according to the Universal Time (UTC)
Any new policy you create from a template automatically applies the template’s setting, which you can then modify. The system displays schedule details for templates in the list on the Templates Interface. A clock icon represents Active at Specified Times, and Always Active shows no icon.
Weekly Calendar
The weekly calendar at the bottom of the schedule section is where the schedule is set.
Schedule section in a policy set to Always Active
When you set the schedule to Always Active, the weekly calendar appears grayed out.
Schedule section in a policy set to Active at Specific Times
When you set the schedule to Active at Specified Times, the weekly calendar becomes active. Each block of time on the calendar represents a 30-minute period.
  • Blue blocks – Active times for the enabled policy
  • White blocks– Inactive times for the enabled policy
The schedule can be set or modified in one of the following ways:
  • Click an individual time-block to toggle between active and inactive for a single 30-minute period.
  • Click a time-block in the All row to toggle between active and inactive for an entire column (for all days of the week).
  • Click the name of a day to toggle between active and inactive for an entire row (for a full day).
