Secure Password Policy Enforcer Web
Netwrix designed Password Policy Enforcer Web to operate securely, but you must ensure that the web server is also secure. Follow Microsoft's recommendations to secure the web server, and always install and use an SSL certificate if you use Password Policy Enforcer Web on an unencrypted network.
Install an SSL Certificate
Password Policy Enforcer Web sends passwords to the domain controllers over a secure connection, but you need to set up SSL (Secure Sockets Layer) encryption for the connection between the web browser and the web server.
Don't use Password Policy Enforcer Web on a production network without SSL encryption.
You can use a self-signed certificate, but most organizations purchase certificates from a certificate authority. This is a recurring cost, and you must complete forms for the certificate authority to verify your identity. You can install Password Policy Enforcer Web on a server that already has an SSL certificate to avoid purchasing another one.
The IIS documentation explains how request, install, and use SSL certificates.
See the Configure Server Certificates in IIS 7 Microsoft knowledge base article for additional information.
Ensure that users only access Password Policy Enforcer Web over an encrypted connection after you install the SSL certificate. The URL should start with https://. You can redirect web browsers to always use the secure URL.
