Active Directory LDAP Connection Failures to Domain Controllers
Symptom
Creating or testing an Active Directory connection under Directory Services fails, returns an authentication or connection error, or times out. Synchronization jobs may also complete without errors but import no users, computers, or groups. This can occur when configuring a new connection or after a previously working connection stops functioning.
Cause
Invalid or Expired Service Account Credentials
The account configured in the Username and Password fields no longer authenticates. This happens when an administrator changes the account password in the domain without updating Netwrix Endpoint Protector, or when someone disables or locks the account, or the account expires.
Incorrect FQDN, Hostname, or IP Address
The Server field contains the address of a domain controller that is unreachable or decommissioned, or someone entered it incorrectly. This includes cases where the field holds an IP address instead of a fully qualified domain name (FQDN) and the IP address later changed.
Insufficient Privileges for the Synchronization Account
The account has valid credentials but lacks read access to the organizational units (OUs), users, computers, or groups being synchronized. This happens when no one delegated permissions on the target OU, or someone removed them.
Network or Firewall Restrictions Between the Endpoint Protector Server and Domain Controllers
A firewall, network segmentation change, or VPN configuration blocks the LDAP port (389) or LDAPS port (636) between the Endpoint Protector Server and the domain controller.
Typos or Misconfiguration in Endpoint Protector Directory Services Settings
A manual entry error in the Server, Port, Connection Type, or Base Search Path fields causes the connection to fail even though the domain controller itself is reachable and healthy.
Resolution
Verify Service Account Credentials
- Confirm the account is enabled and not locked out in Active Directory.
- Confirm the password has not expired or been changed since it was configured in Endpoint Protector.
- In Directory Services > Microsoft Active Directory, update the Username field using the format
svc-eppsync@netwrix.comorNETWRIX\svc-eppsync, and re-enter the Password. - Click Test to confirm the connection succeeds.
Verify FQDN, Hostname, or IP Configuration
- Confirm the correct FQDN for the target domain controller, for example
dc1.netwrix.com. - From the Endpoint Protector Server, confirm DNS resolves the FQDN correctly:
nslookup dc1.netwrix.com
- Use the FQDN in the Server field rather than a static IP address, especially when the connection uses LDAPS with a certificate bound to the FQDN.
- If a static IP address must be used, confirm it has not changed and is reserved (not subject to DHCP reassignment).
Verify Synchronization Account Privileges
- Confirm the synchronization account requires only read access to the target OUs, users, computers, and groups. Domain Administrator rights are not required.
- In Active Directory Users and Computers, review the effective permissions on the target OU and confirm the account (or a group it belongs to) has read access delegated.
- Re-test the connection and attempt to browse the target OU in the Directory Browser section after adjusting delegation.
Verify Network and Firewall Connectivity
- From the Endpoint Protector Server, confirm the domain controller is reachable on the required port:
On Windows, usetelnet dc1.netwrix.com 389# or, for LDAPStelnet dc1.netwrix.com 636
Test-NetConnection -ComputerName dc1.netwrix.com -Port 389instead. - If the connection fails, confirm firewall rules allow outbound traffic from the Endpoint Protector Server to the domain controller on port 389 (LDAP) or 636 (LDAPS).
- Confirm no proxy, VPN, or network segmentation change has altered the route between the Endpoint Protector Server and the domain controller since the connection last worked.
Review Endpoint Protector Directory Services Configuration for Typos
- Re-enter the Connection Type, Server, and Port fields in Directory Services > Microsoft Active Directory, confirming the port matches the selected connection type (389 for LDAP, 636 for LDAPS).
- Confirm the Base Search Path syntax is correct, for example
OU=Users,DC=netwrix,DC=com. - Click Test after each change to confirm the connection succeeds before saving.
