Understanding the Rights Hierarchy for Devices
Overview​
This article explains the rights hierarchy for devices, which determines how Netwrix Endpoint Protector applies and overrides permissions.
The rights hierarchy for devices, from lowest to highest, is as follows:
  1. Global Rights
  2. Group Rights
  3. Computer or User Rights
  4. Devices
  5. Custom Classes
Priority order when configuring device rights
Computer Rights and User Rights share one level. To choose which takes precedence, follow the steps in Instructions.
Custom Classes override all other rights. Use Custom Classes to globally set rights for a device or class of devices identified by Vendor ID (VID), Product ID (PID), and Serial Number.
For the full reference, see Priority order in the Devices and Computers documentation.
NOTE: If you do not configure device rights, the device uses the default Global Rights set per Device Type (USB Storage Device, Digital Camera, iPod, Thunderbolt, Chip Card Device, etc.). See Directory Services for more detail on how these defaults interact with directory-synced entities.
Instructions​
To set precedence between Computer Rights and User Rights, go to System Configuration > System Settings and select the desired option.
System Settings page showing precedence configuration for Computer or User Rights
