Assignment Policy
The Role Model
The Introduction Guide introduced the role model and how it influences assigning entitlements to identities. Let's sum up the key principles here. See the Entitlement Management topic for additional information.
  1. Identities are resources.
  2. Assignments of entitlements are materialized by resources, their values and associations.
  3. Identity Manager uses a role-based assignment policy to grant entitlements to identities, i.e. granting a role entails granting entitlements.
  4. The role model is first a catalog of available roles ( Single Role and Composite Role ), identified by meaningful names aimed at non-technical end-users. These roles represent status of trust and privileges, to be assigned to identities, manually or automatically.
  5. The role model is also a set of rules aiming at assign automatically roles to identities, based on relevant criteria, namely Dimension .
  6. The role model classifies resources by security concerns thanks to resource types.
  7. The role model contains correlation rules identifying ownership of target resource by an identity.
  8. The role model contains provisioning rules describing if and how target resources and their values should be computed from source resource values.
Resource types, single roles and composite roles can be grouped into Category . They are used in the UI to organize the Roles catalog display. Categories are organized in a hierarchical tree structure.
Policy
Dimensions And Contexts
Every identity in the organization operates within a specific context. It is a set of information relevant to making decisions about assigning entitlements for an identity. For example, an employee working in the R&D department of the New York office at Contoso Corporation is associated with the {R&D, New York} context.
The integration team defines Context Rule and Record Section in the applicative configuration that assigns, for every identity, a context as a set of dimension-value pair.
The details of how contexts are generated can be found in Generate Contexts .
Example
  • Location, the physical location where an employee works.
  • Department, the employee working department, such as IT, Sales or Accounting.
For a rule such as "every employee that works in IT must have access to the servers room", the ServerRoomAccess single role would be assigned to every resource of entity type employee whose context contains the value IT for the dimension Department.
A context rule would have been written first, defining for every resource of entity type employee how to compute a context: the Department dimension value is found in the department property of the resource, the Location dimension value is found in the site property of the resource.
Write Roles And Assignments Rules
The role model is built iteratively, together with the Entity Model, as they closely influence one another. See the Entity Model topic for additional information.
The role model evolves and lives during the whole IGA project's lifecycle. Organization rules change, roles and assignment rules are updated, deleted, added.
1. Identify single roles
Example
Everyone in the team needs to access the Internet to do research and send e-mails. That's a first typical single role Internet Access that everyone should be assigned to be able to work.
Aerodynamics engineers need to access remote high-performance computation servers specifically designed to solve aerodynamics equations. The sensitive nature of the data sent to those servers, plus the availability constraints, require restricting access to engineers that absolutely need it to perform their daily tasks. That's another responsibility, that can be translated to a single role Aerodynamics Computation Server for example, that grants access to those servers.
Structure engineers, on the other hand, do not perform such heavy computations and do not need access to the aerodynamics computation server. They can work locally, performing computations on their own workstation. They're not assigned the Aerodynamics Computation Server role.
Quality control agents need access to sensitive information such as accident reports, on the internal data server named data0. Those highly sensitive privileges are not assigned to everyone. They can be translated to the Data Server data0 role.
The project manager needs access to the data0 and data1 servers with client contracts. The Data Server data0 and Data Server data1 roles translate those responsibilities.
2. Identify navigation rules and ownership
They are materialized by:
  • Provisioning rules, such as Resource Type rules that decide what resources should be found in the managed systems; and navigation rules or scalar rules, that identify actual values to be fulfilled from the identity to which the single role is assigned;
  • Resource Correlation Rule that identify for an identity, the target resources to fulfill;
  • Resource type that organize resources and describe a source/target (or owner/resource) relationship.
Example
Let's consider the Internet Access defined at step 1.
A security officer, to grant Internet access to an employee, would in practice assign a Internet Access group membership to their Active Directory account. That is a fine-grained entitlement entailed by the assignment of the Internet Access single role. That means that, to be able to grant or restrict Internet access, the link between an identity and their Active Directory account, used to login to work, must be known.
To modelize that need within the role model, every identity with Internet Access single role is associated with an Active Directory account. We can find the Active Directory for an identity by comparing the identity email with the Active Directory entry e-mail. That's an example of Resource Correlation Rule that define the ownership of an Active Directory entry resource by an identity resource.
3. Write assignment rules
Example
The need for aerodynamics engineers to access the remote computation server is translated by a single role rule: if the department (a dimension) of that identity is Aerodynamics R&D (a dimension value), then the Aerodynamics Computation Server single role must be granted.
The need for assignment of the Internet Access group to the Active Directory account, if the identity is assigned the Internet Access single role is modeled by a navigation rule that stipulates that if that identity is assigned that role, then the memberOf property of the owned Active Directory entry resource should be set to the AD group named Internet Access.
4. Use Composite Roles To Organize Single Roles (optional)
Single Role can be packaged into Composite Role . Assigning a composite role to an identity immediately assigns the packaged single role to that identity. Single roles assigned this way are said to be inferred.
Summary - A mental model to help build a role model
  1. A resource-identity Ri is associated with a context Ci, i.e. dimension values.
  2. Ri is assigned a single role SRa, manually or as a result of dimension comparisons.
  3. Identity Manager's engine identifies a resource type Rt with the type rule Tr whose condition matches SRa and/or Ci.
  4. Using Rt's definition, Identity Manager's engine identifies by correlation a target resource Tr from the resource repository that must be created or updated to materialize SRa.
  5. Identity Manager's engine identifies Rt's navigation rule Nr whose condition matches SRa and/or Ci, and associated scalar rules Sr.
  6. Using Sr and Nr's definition, Identity Manager's engine identifies Tr's values to be provisioned to materialize SRa.
Cascading From Dimensions To Roles To Provisioning Orders
Evaluate Policy
This chapter gives the basis of the assignments vocabulary. The next chapter enlightens the reader about the inner details of the Evaluate Policy algorithm. See the Evaluate Policy topic for additional information.
