Generic SQL
Exports data from a SQL database.
Package CharacteristicsValue
Display NameDatabase/Generic SQL
IdentifierUsercube.SQL@0000001
ExportUsercube-Export-Sql.dll
FulfillNONE
Has Incremental ModeFalse
PublisherIdentity Manager
When creating a connection to a database which is not handled by Identity Manager's packages, you'll need to fill in the ProviderDllName and ProviderClassFullName properties of the Sql connector using the procedure given in the example.
