Write a Robot Framework Script
This guide shows how to write a Robot Framework script that will be used by Robot Framework .
Structure of a Robot Framework Script
Build the skeleton
A Robot Framework script is divided into four main parts:
- Settings: contains the instructions to import library or external resource files.
- Variables: contains the global variables shared by all the functions in the script.
- Keywords: contains all the functions defined by the user.
- Test Cases: contains the functions which will be run when the script is launched.
Example
*** Settings ***
Library Telnet
*** Variables ***
${IPADDRESS} 192.168.1.22
*** Keywords ***
Open Telnet Connection
Open Connection ${IPADDRESS} prompt=$
*** Test Cases ***
Run Provisioning
Let's analyze the four parts of this example:
- Settings: we import here the Telnet library to use the functions defined in it.
- Variables: we define the variable
IPADDRESS
to use it later. - Keywords: we define a custom function called
. It will use a function defined in the Telnet library (calledOpen Connection
) and the variableIPADDRESS
which has been defined before in theVariables
section. - Test Cases: we define here the main function which we choose to call
Run Provisioning
(it can be named anything), and which will be run when launching the script. It will use the functionOpen Telnet Connection
Robot Framework needs two spaces between two different instructions to parse them correctly.
For example, Open Connection
consists of only one instruction. Only one space is thus needed
between the two words. But, Open Connection ${IPADDRESS}
consists of two instructions, the
function and the parameter. Two spaces are then required to separate Connection
from
${IPADDRESS}
To read your script more easily, you could also use the pipe character (|
) between instructions,
like this: Open Connection | ${IPADDRESS}
See the Robot Framework Libraries for additional information.
Define specific functions
To use a Robot Framework script for provisioning external systems with Identity Manager, the following elements are required in the script:
- The import of a resource file written by Identity Manager called
UsercubeRobotFramework.resource
. - The definition of three functions which will be called by Identity Manager to perform three
required actions:
ExecuteAdd
,ExecuteDelete
andExecuteModify
. These functions are where you will write the actions to perform on the external system. - The use of one function to start the provisioning called
Launch Provisioning
Never modify the resource file UsercubeRobotFramework.resource
Example
The resource file defined at the beginning of the script is located in Identity Manager's Runtime
folder. Therefore, you will have to change the path accordingly.
*** Settings ***
Resource C:/identitymanagerContoso/Runtime/identitymanagerRobotFramework.resource
*** Keywords ***
ExecuteAdd
[Arguments] ${order}
ExecuteDelete
ExecuteModify
*** Test Cases ***
Run Provisioning
Launch Provisioning
The parameter ${order}
is mandatory only for the three functions: ExecuteAdd
, ExecuteDelete
and ExecuteModify
. It is an object corresponding to the following sample provisioning order
(JSON):
"ChangeType": "Added",
"WorkflowInstanceId": "81",
"Owner": {
"Id": "21511",
"Identifier": "007",
"EmployeeId": "007",
"PhotoTag": -3065,
"MainFirstName": "James",
"MainLastName": "Bond",
"ResourceType": {
"Id": "-41",
"SourceEntityType": {
"Id": "51",
"TargetEntityType": {
"Id": "70",
"Identifier": "RobotFramework_User"
"Identifier": "RobotFramework_User_NominativeUser"
"Changes": {
"identifier": "007",
"firstName": "James",
"lastName": "Bond"
The elements of ${order}
can be accessed like this: ${order['Changes']['identifier']}
See the Robot Framework User Guide for additional information.
Keywords
| Keyword | Details |
| Catch Keyword | Arguments Keyword
: Keyword *args
Description Launches Keyword
with the given arguments *args
if the keyword launched by Try Keyword
failed. If Try Keyword
was not called, this keyword will not do anything. Catch Keyword
should always be called right after Try Keyword
. Example Try to connect to Usercube.com
. If the connection fails, restart the browser and try to connect to Usercube.com
: Connect to URL Try Keyword Go To Usercube.com Catch Keyword Restart Browser At URL Usercube.com
| Generate Password | Description Generates a password based on the Password Reset Settings associated to the Resource Type Mappings being provisioned. Send Password Notification
should always be called after Generate Password
, preferably right after the password is used. If Send Password Notification
is not called before the provisioning of the resource is over, it will automatically be called. If multiple passwords should be generated, Send Password Notification
should be called after each password generation. Returns Password
: string |
| Get Secure Data | Arguments Attribute
: string Erase Data
: boolean Description Retrieves the secured option Attribute
from the connector configuration. If Erase Data
is set to true, the secured option is deleted once it is read. Example Get Login option and erase it: Get Secure Data | Login | True
| Launch Provisioning | Description Launches the provisioning defined by the provisioning orders. This keyword is required for any provisioning to happen. |
| Log Debug | Arguments Message
: string Description Logs Message
at the Debug
log level. Example Log a keyword failure message: Log Debug The keyword has failed
| Log Error | Arguments Message
at the Error
log level. Example Log a keyword failure message: Log Error The keyword has failed
| Send Password Notification | Description Sends a notification containing the last password generated. If Generate Password
is called and Send Password Notification
is not called before the provisioning of the resource is over, Send Password Notification
will automatically be called. |
| Try Keyword | Arguments Keyword
: Keyword *args
, and ignores its errors. If Keyword
fails, the keyword sent to Catch Keyword
will run. Try Keyword
should always be called right before Catch Keyword
Error handling
Consider a web application that contains user information. Suppose a user is missing from the web application. When the script attempts to reach the user's information page, it will reach an error page, and fail. The next user's provisioning starts, but the web browser is still on the error page, so the script keeps failing.
In this example, if a user's provisioning fails, each subsequent provisioning will fail. This failure issue can be solved with the error handling custom keywords.
Consider the following example using the Robot Framework Selenium library:
Open Usercube Website
Open Browser
Connect To Usercube
[Teardown] Close Browser
Restart Browser
[Arguments] ${url}
Log Debug An error has occured, restarting the browser
Close Browser
Open Browser ${url}
Connect To Usercube
Catch Keyword Restart Browser Usercube.com
Page Should Contain Usercube
In this example, the keyword Open Usercube Website
opens a browser, then calls
Connect To Usercube
. To ensure that the browser is closed regardless of the script's success, the
Close Browser
keyword is used in a teardown. A keyword in a teardown is always executed regardless
of what happens in the script or in the teardown.
The Restart Browser
keyword logs a debug message before restarting the browser to help debug the
script. The Connect To Usercube
tries to use the Go To
keyword to connect to the Usercube.com
web page. As Go To
is used with Try Keyword
, if the execution fails, Restart Browser
is called
by Catch Keyword
. This means that if the browser fails to load Usercube.com
, the browser
restarts. Last, Connect To Usercube
verifies that the page contains the word Usercube
Error Handling for ExecuteAdd, ExecuteDelete, and ExecuteModify
The ExecuteAdd
, ExecuteDelete
, and ExecuteModify
methods are harder to interact with. First,
it is not possible to get their execution status within the script. Second, if the execution failed,
it should be kept as a failure in order to log the failure.
To simplify error handling, consider the following structure:
Execute Add
Try Keyword Add User ${order}
Catch Keyword Restart Program And Fail Add User failed.
Add User
Click New User
Fill In Information ${order}
Click Add User
[Arguments] ${failmessage}
Close Program
Start Program
Fail ${failmessage}
In this example, ExecuteAdd
does not call the custom keywords to add a new user directly, and only
calls Add User
instead. This means that it is possible to call Add User
from the Try Keyword
keyword. If Add User
fails, then Execute Add
fails. Therefore it is possible to catch a failure
with this structure.
Note that Restart Program And Fail
fails. This failure is necessary as the provisioning order
would be counted as a success otherwise.
Testing a RobotFramework script
In order to write a RobotFramework script, we need to test that it works. It is possible to test the script by running a fulfillment job from the Identity Manager interface. While this kind of test proves that everything works as expected, it can take a long time. There is a faster method to check that the script runs.
Suppose the RobotFramework script's path is RobotFramework/script.robot
We need the following elements :
- A provisioning order, in folder
RobotFrameworkScript/Order
. The provisioning order can be encrypted or unencrypted. The script will write the encrypted results toRobotFrameworkScript/Order/results.csv
. - The path to the
Runtime
folder. In our example, we will consider this path asC:/identitymanagerDemo/Runtime
The RobotFramework/script.robot
script may be run from the command prompt.
cd RobotFramework
robot --variable ORDERPATH:./Order --variable RUNTIMEPATH:C:/identitymanagerDemo/Runtime --variable RESULTPATH:./Order/results.csv ./script.robot
This command will generate an output file, a log file, and a report file in the RobotFramework
folder. This command will also write information to the command prompt.
For most testing cases, we only care about the command prompt information and the log file, written
at RobotFramework/log.html
. The other outputs can be removed.
cd RobotFramework
robot --loglevel NONE --report NONE --variable ORDERPATH:./Order --variable RUNTIMEPATH:C:/identitymanagerDemo/Runtime --variable RESULTPATH:./Order/results.csv ./script.robot
Get Secure Data
and Generate Password
Most keywords are not different when a script is launched manually. The keywords Get Secure Data
are exceptions.
Get Secure Data
: This keyword expects the Robot Framework process to receive a json list of attributes in the stdin stream. This can be provided manually by writing the data in the command prompt. As an example, if the script requires aLogin
andPassword
attribute :{"Login":"login","Password":"password"}
Generate Password
: This keyword expects a file that contains the Password Reset Settings associated to the provisioned Resource Type Mappings. The easiest way to enable theGenerate Password
keyword is as follow:- Launch the Robot Framework fulfillment through the Identity Manager web application with a blank script.
- Copy the
PasswordResetSettings
folder generated in the most recent subfolder ofWork/FulfillRobotFramework
. - Paste the folder in the same folder as the provisioning order.
Use Case: Write a Script to Fulfill a CSV File
The goal of the script is to append, for each provisioning order, a line in a CSV file located on an external system which we will access through a Telnet connection.
Let's consider the following ResourceType
<ResourceType Identifier="RobotFramework_User_NominativeUser" DisplayName_L1="Robot Framework User (nominative)" Policy="Default" TargetEntityType="RobotFramework_User" Category="RobotFramework" SourceEntityType="Directory_User" ApprovalWorkflowType="One"> <ScalarRule Property="identifier" Binding="EmployeeId"/> <ScalarRule Property="firstName" Binding="FirstName"/> <ScalarRule Property="lastName" Binding="LastName"/></ResourceType>...
Insert;007;James;Bond
Define settings
In every Robot Framework script, we need to import the resource file
. In this example, we also need to import the Telnet library to use
its functions.
*** Settings ***
Library Telnet
Define variables
To connect to the external system through Telnet, we need an IP address corresponding to the
external system. We will store the IP address in the global variable ${IPADDRESS}
. We also use the
global variable ${CSVFILEPATH}
to define the CSV file where the data will be written in the
external system.
*** Variables ***
${CSVFILEPATH} /home/contoso/robotframework_users.csv
Define custom keywords
We define all the custom functions which we will use to provision the external system:
Delete CSV File
: removes a possible pre-existing CSV file.Write In CSV
: executes a command to write the line in the CSV file in the external system.Write Data
: formats the line to write in the CSV and callsWrite In CSV
to write it.Write Header
: defines the header to write in the CSV and callsWrite Data
to write it.Open Telnet Connection
: opens the Telnet connection to the external system using the login and the password defined in the Robot Framework attribute inappsettings.agent.json
, as well as the IP address defined in theVariables
section.
*** Keywords ***
Delete CSV File
Execute Command rm ${CSVFILEPATH}
Write In CSV
[Arguments] ${line}
Execute Command echo ${line} >> ${CSVFILEPATH}
Write Data
[Arguments] ${command} ${identifier} ${firstName} ${lastName}
Write In CSV '"${command}","${identifier}","${firstName}","${lastName}"'
Write Header
Write Data Command identifier firstName lastName
Read Until login
${LOGIN}= Get Secure Data Login False
Write ${LOGIN}
Read Until Password
${PASSWORD}= Get Secure Data Password True
Write ${PASSWORD}
The method Get Secure Data
will retrieve the value of the attributes filled in the options in
. This is the method strongly recommended by Identity Manager. However, you
could also enter the value directly into the script (example: ${LOGIN}= UserName
). This may be
easier for initial testing purposes.
Define mandatory keywords
To be able to provision the external system, we need the three required functions: ExecuteAdd
ExecuteDelete
and ExecuteModify
. These methods are called by the connector depending on the
action to perform on the external system.
*** Keywords ***
ExecuteAdd
Write Data Insert ${order['Changes']['identifier']} ${order['Changes']['firstName']} ${order['Changes']['lastName']}
ExecuteDelete
Write Data Delete ${order['Changes']['identifier']} ${order['Changes']['firstName']} ${order['Changes']['lastName']}
ExecuteModify
Write Data Update ${order['Changes']['identifier']} ${order['Changes']['firstName']} ${order['Changes']['lastName']}
Here, for each action, we use the function Write Data
defined in the previous section to write the
changes to the CSV file with a corresponding word Insert
, Delete
or Update
Define test cases
The function launched by the Robot Framework script will be written in the section Test Cases
and
will be called Run Provisioning
*** Test Cases ***
Run Provisioning
Delete CSV File
Write Header
Launch Provisioning
Close All Connections
In our test case, we will perform the following operations in Run Provisioning
- Open the Telnet connection with the external system.
- Remove a possible pre-existing CSV file.
- Write the header to the new CSV file.
- Launch the Identity Manager provisioning. The method
Launch Provisioning
is mandatory when using the Robot Framework connector. - Close the Telnet connection with the external system.
Read the full script
*** Settings ***
Library Telnet
*** Variables ***
*** Keywords ***
ExecuteAdd
ExecuteDelete
ExecuteModify
Delete CSV File
Write In CSV
[Arguments] ${line}
Write Data
Write Header
Read Until login
Write ${LOGIN}
Read Until Password
Write ${PASSWORD}
*** Test Cases ***
Run Provisioning
Delete CSV File
Write Header
Launch Provisioning
