Write a PowerShell Script for Provisioning
This guide shows how to write a PowerShell script used by the PowerShellProv connector.
Structure of a PowerShell Script
The goal of the script is to append, for each provisioning order, a line in a CSV file.
Let's consider the following ResourceType:
<ResourceType Identifier="PowerShellCsv_User_NominativeUser" DisplayName_L1="PowerShell CSV User (nominative)" DisplayName_L2="Utilisateur PowerShell CSV (nominatif)" Policy="Default" TargetEntityType="PowerShellCsv_User" Category="PowerShellCsv" SourceEntityType="Directory_User" RemoveOrphans="true" AllowAdd="true" AllowRemove="true"> <ScalarRule Property="identifier" Binding="EmployeeId"/> <ScalarRule Property="firstName" Binding="FirstName"/> <ScalarRule Property="lastName" Binding="LastName"/></ResourceType>...
insert;007;James;Bond
Define the common part of every script
The goal of the common part is to get all required variables needed by the script.
Two parameters are required at the top of the script:
param(
[Parameter(Mandatory = $true)][string]$resultsFilePath,
[Parameter(Mandatory = $true)][string]$ordersPath
  • resultsFilePath is the agent-side path of the result file containing the summary of the executed and errored orders.
  • ordersPath is the agent-side folder path containing the JSON provisioning orders.
It is important for these settings to be defined at the top of the script and keep these names because they are filled by the Fulfill-PowerShell connector.
The Fulfill-CSV.ps1 script must be placed in the script folder of Identity Manager containing the Environment.ps1 script. Thanks to this, environment variables (such as $runtimePath) are loaded and can be used in the script:
. (Join-Path -Path $PSScriptRoot -ChildPath "Environment.ps1")
. (Join-Path -Path $runtimePath -ChildPath "Usercube-Visit-Orders.ps1")
Define the specific function
A function which is called for each provisioning order must be defined.
Define the header
The header is always the same. Only the name of the function can change:
function Fulfill-CSV {
param ([parameter(Mandatory = $true)] $order)
The previous parameter $order is an object corresponding to the following provisioning order (JSON):
"ProvisioningOrdersList": [
"ChangeType": "Added",
"WorkflowInstanceId": "81",
"Owner": {
"Id": "21511",
"Identifier": "007",
"EmployeeId": "007",
"PhotoTag": -3065,
"MainFirstName": "James",
"MainLastName": "Bond",
"ResourceType": {
"Id": "-41",
"SourceEntityType": {
"Id": "51",
"TargetEntityType": {
"Id": "70",
"Identifier": "PowerShellCsv_User"
"Identifier": "PowerShellCsv_User_NominativeUser"
"Changes": {
"identifier": "007",
"firstName": "James",
"lastName": "Bond"
There can be more sections and attributes.
Define mandatory parameters
The ChangeType parameter (Added, Deleted or Modified) is always mandatory and must be checked.
Depending on the function requirements, other parameters should be checked. For example, the function below always needs an identifier to work properly, therefore you should check its presence.
$changeType = $order.ChangeType
# if the change type is not recognized, we throw an error
if ($changeType -ne 'Added' -and $changeType -ne 'Deleted' -and $changeType -ne 'Modified') {
$artId = $order.AssignedResourceTypeId
throw "Order ChangeType: $changeType not recognized in AssignedResourceTypeId: '$artId'"
# if the section is Changes, we want to create/update the identifier
$identifier = $order.Changes.identifier
if(!$identifier){
# if the section is Resources, we want to keep the same identifier
$identifier = $order.Resource.identifier
if(!$identifier){
throw "identifier is the primary key and must not be null."
Define order processing
This is the last part of the function:
  • Parameters from the provisioning order are stored in variables.
  • A specific treatment is applied if ChangeType is Added, Deleted or Modified.
# firstName and lastName are the two other properties of the ResourceType
$firstName = $order.Changes.firstName
$lastName = $order.Changes.lastName
# change type defines what is written in the 'command' column
if ($changeType -eq 'Added') {
$command = "Insert"
elseif ($changeType -eq 'Deleted') {
$command = "Delete"
elseif ($changeType -eq 'Modified') {
$command = "Update"
# CSV columns are command, identifier, firstName and lastName
$script:powershellResults += New-Object -TypeName psobject -Property @{Command = "$command"; identifier = "$identifier"; firstName = "$firstName"; lastName = "$lastName" }
Define how to send logs to Identity Manager
The three methods to log in Identity Manager are:
  • Write-Host: writes Information in the log.
  • Throw: raises an exception (which stops the script), and writes the Error in the log (the provisioning order will be errored too).
  • Write-Error: writes Error in the log (the provisioning order will be errored too). It is not recommended because the script continues its execution.
Now that the function has been defined, the main code of the script can be written.
Write the main code of the script
Read the options parameter from the standard input
The options parameter isn't mandatory in the JSON file. If it isn't provided, don't perform this step.
# Just to show how to read the options in the script
$options = [System.Console]::ReadLine()
$options = ConvertFrom-Json $options
$options.Message # -> Hello
Rest of the main script
In general, this part contains the code to connect to the external system and executes the Usercube-Visit-Orders script.
# The goal of the script is to write the users in the following CSV file
$powershellResultFilePath = Join-Path -Path "$demoPath" -ChildPath "Temp/ExportOutput/powershellcsv_users.csv"
# powershellResults has a larger scope and is used in the last line of the Fulfill-CSV function
$powershellResults = @()
# Usercube-Visit-Orders is provided by Usercube, it must not be modified
# It loops on the provisioning orders and calls Fulfill-CSV on each of them
Usercube-Visit-Orders $resultsFilePath $ordersPath Fulfill-CSV
# We write the results in $powershellResultFilePath
if ($powershellResults.Length -gt 0){
$powershellResults | ConvertTo-Csv -Delimiter ";" -NoTypeInformation | & (Join-Path -Path "$runtimePath" -ChildPath "Usercube-Encrypt-File.exe") -o $powershellResultFilePath
Never modify Usercube-Visit-Orders.ps1.
Synthesis
Skeleton
To sum up the previous part, the script can be written as follows:
# Common part
# Specific function
# Header of the function
# Check mandatory parameters
# Order processing (treatment for Added, Deleted or Modified)
# Main script
# Read standard input (Optional)
# Rest of the main script (Connection, Usercube-Visit-Order...)
Full script
# Common part
param(
# Specific function
if(!$identifier){
if(!$identifier){
$command = "Insert"
$command = "Delete"
$command = "Update"
# Main script
