synchronize Data
How to launch data synchronization, i.e. read managed systems' data and load it into Identity Manager.
Overview​
Data synchronization is a data flow from the managed systems into Identity Manager.
Process​
A connector's main purpose is to read and export the data previously mapped with Create an Entity Type to synchronize it with Identity Manager. Connectors provide tools to perform a basic extraction of the system's data in the form of CSV/XLSX files. These files are cleansed and loaded into Identity Manager. Synchronization is a three-step ETL process going through export, synchronization preparation and the synchronization itself.
Synchronization Schema
export​
The export Task creates extractions, a snapshot of the managed system's data, used to insert and/or refresh the data that is inside Identity Manager. extractions are accessible when there is at least one connection with an export-enabled References: Packages. Extracted data becomes meaningful when it is loaded into resources as specified by the entity type structure.
Exported data is stored inside CSV files in the folder /{InstallationFolder}/Temp/ExportOutput.
Prepare synchronization​
The Prepare Synchronization Task performs a preparatory data cleansing to spot errors and list them in a generated file in the /{InstallationFolder}/Work/Synchronization folder.
For example, this task spots an identity if it is linked to an organization code which doesn't exist.
synchronize​
The **synchronize** task loads data into Identity Manager's database.
See the Upward Data Synchronization topic for additional information.
Prerequisites​
Extracted data must have keys​
Every extracted resource must have an attribute that serves as a primary key so that Identity Manager can uniquely identify the resource to be added/updated/deleted during synchronization. You must have defined keys during Entity Type creation. See the Create an Entity Type topic for additional information.
extractions must not be modified before synchronization
extractions must not be modified manually, for it may induce synchronization issues.
For example, saving an XLSX file implies an automatic modification of format.
Also, synchronization must not be disturbed by a change in the source format, such as the deletion of a column in the middle of the file.
Thresholds must never be deactivated
Thresholds are essential safety guards that control all changes, for example preventing the overwriting of important data by mistake. Thresholds are by default activated to warn users when synchronization or provisioning triggers too many modifications. If the number of modifications exceeds the specified threshold, Identity Manager stops the synchronization and displays a warning "Threshold Exceeded" on the subsequent log page.
After the changes are reviewed, the blocked job can be resumed (or not).
Thresholds are configured with default values using the following Connector attributes:
  • MaximumDeletedLines, MaximumInsertedLines and MaximumUpdatedLines for scalar properties;
  • MaxPercentageDeletedLines, MaxPercentageInsertedLines and MaxPercentageUpdatedLines for scalar properties by percentage;
  • MaximumLinkDeletedLines, MaximumLinkInsertedLines and MaximumLinkUpdatedLines for navigation properties;
  • MaxLinkPercentageDeletedLines, MaxLinkPercentageInsertedLines and MaxLinkPercentageUpdatedLines for navigation properties by percentage.
Participants and Artifacts​
At this point, integrators should have all the elements they need to perform synchronization.
InputOutput
Connector with its entity types (required)Synchronized data
See the Connect to a Managed System topic for additional information.
Launch Synchronization​
Launch synchronization for a given managed system by proceeding as follows:
  1. Access the list of connectors by clicking on Connectors on the home page in the Configuration section.
    Home - Connectors
  2. On the relevant connector page, in the Entity Types frame, click Jobs.
Here are all the tasks available for synchronization. They synchronize all connections and entity types for only this connector. Launch them individually to test them and debug a situation, or all together with All Tasks. According to the created connections and packages, all these tasks can be launched either in incremental or complete mode.
synchronize Job
  • Update Expressions: computes the expressions used in the entity type mapping.
  • All Tasks: launches all previous tasks in a row.
Notice that some connectors, depending on their connections and packages, can't be synchronized in incremental mode. As a consequence, when clicking on the Jobs button, you wouldn't have a choice between Complete and Incremental. In this case, the following image shows a synchronize Job with only the Complete option available.
synchronize Job (Only Complete)
Manage Synchronization Automation​
export and synchronization are executed manually from the connector screens. By default, they are also part of scheduled Jobs provided by Identity Manager:
  • the complete job is scheduled to launch a synchronization once a day of all resources, modified, or not;
  • the incremental job is scheduled to launch a synchronization several times a day only of the resources modified since the last synchronization.
See the Set Up Incremental Synchronization and Set up Complete Synchronization topics for additional information.
Scheduling the jobs avoids manually triggering them everyday.
However, you can choose to withdraw a given connector from both the complete and incremental jobs by clicking on Deactivate on the connector's dashboard. This is particularly useful when modifying a connector. You can also re-insert it at any time with the same button which is now named Activate.
Jobs Results Dashboard
You can fine-tune the synchronization and/or provisioning of the connector by clicking on the Edit button.
Edit button
Click Job Results to access the progress of this connector's jobs.
All jobs are accessible on the Job Execution page in the Administration section.
Home - Job Execution
Verify an Entity Type's Synchronization​
To verify both the synchronization configuration and Create an Entity Type:
  1. Launch synchronization.
  2. Access the connector's logs (from Job Results on the connector's dashboard) to ensure that synchronization completed successfully.
    Jobs Results
  3. Check that the entity types have been added to the left menu of the home page.
    Test Entity Type
  4. Access the relevant entity types (from the menu items on the left of the home page) to check synchronized resources, by navigating in the UI from the accounts through a sample of associations, via the eye icon:
    Eye Icon
You should first look for configuration validation, and only later validation of the actual data being synchronized.
For example, let's say we created a connector for SAB that contains two entity types called SAB - Users and SAB - Groups. Then, the home page shows them on the left.
SAB Example - Home Page
Clicking on SAB - Users displays the list of all synchronized resources.
SAB Example - Data List
Clicking on any resource displays its detailed attributes, for example Abbott Mark:
SAB Example - Resource Attributes
Clicking on any eye icon displays the corresponding resource. SAB was created here with a simple user-group schema that links n users to n groups. So here, we can check these links by navigating from a given user to one of their groups, to one of said group's users, to one of said user's groups, etc.
Troubleshooting​
Ensure you followed the prerequisite guidelines for synchronization.
A problem observed in synchronized data might also come from a mistake made previously in the connector's configuration. Logs can give more details. Logs are accessible from the Job Results button on the dashboard of a given connector.
Don't hesitate to launch synchronization-related tasks individually and observe the corresponding logs to debug a situation.
If the connector and/or entity type doesn't appear in the menu items, then:
Test Entity Type
Access the relevant connector's page and click the Reload button to take into account the last changes in the entity type mappings.
If a newly added property doesn't appear in users' data, then:
Access the relevant connector's page to click the Reload button to take into account the most recent changes in the entity type mappings.
If a synchronization is blocked by an exceeded threshold, then:
Threshold warning
Find out the reasons to decide whether to bypass the threshold. Proceed as follows:
  1. On the logs page (accessible from the Job Results button), click the line of a task instance to see its logs.
  2. Study synchronization counters and the list of all synchronization changes. These tools help you make a decision about whether to bypass synchronization thresholds.
    Job progress
In most cases, the first synchronization exceeds thresholds because no data exists in Identity Manager yet. Thus, a high quantity of modifications is expected and the synchronization is to be resumed.
Numerous modifications can also be triggered by:
  • a change in date format;
  • the input of blank files by mistake, because it would overwrite and erase all existing data;
  • a swap of two headers in an input file.
  1. If, after verifying, all changes are legitimate, click the Resume button at the top of the job progress page. This will restart the job and allow the changes to be synchronized.
Be cautious, check twice for mistakes before resuming.
Resumed Job
If an export doesn't complete, then:
  • Check the connection's settings.
  • If you manually typed the source column of a property in the entity types, then ensure that the source column exists in the corresponding managed system.
    Source Column
If a given property from users' data is displayed in an unexpected way, then:
Check the format of both the application metadata and the external system.
Property Format
For example, if you find that a given date doesn't comply with what you set, then maybe the format in the External System section wasn't correctly selected, thus inducing a conversion error during the export computation.
