Connect to a Managed System
How to create a new Connector using the provided SaaS agent. See the Architecture topic for additional information.
Identity Manager provides demo applications Run the Banking Demo Application and Run the HR Demo Application to help set up connectors, test them, and understand Identity Manager's abilities towards external systems.
Overview​
Connectors are the mechanisms that enable Identity Manager to read and write data to/from your organization's systems. The feedback mechanism ensures Identity Manager's reliability.
This documentation uses the term managed systems (sometimes called external systems) to refer to third-party applications, i.e. the applications used in your organization, such as Active Directory, ServiceNow, EasyVista, SAP, SharePoint, etc.
A connector, therefore, acts as an interface between Identity Manager and a managed system.
Connector Schema
NETWRIX strongly recommends the creation of one connector for one application.
For example, integrators may create an AD connector with the goal of importing an Active Directory's data into Identity Manager, and writing to the Active Directory from Identity Manager, either manually for administration accounts, or automatically for basic accounts.
Integrators may create a SharePoint connector to manage read and write entitlements for users in SharePoint.
Data Flows​
In the early steps of a project, most connectors are outbound, i.e. Identity Manager feeds data into connected managed systems.
Outbound System=
In this case, data flows between Identity Manager and the managed system are also called:
  • synchronization in the "managed system-to-Identity Manager" direction;
  • provisioning in the "Identity Manager-to-managed system" direction.
For a connector's synchronization, Identity Manager provides tools to perform a basic extraction of the system's data in the form of CSV files. These files are cleaned and loaded into Identity Manager. In other words, synchronizing means taking a snapshot of the managed system's data and loading into Identity Manager.
For provisioning, Identity Manager generates provisioning orders and the connector provides tools to either automatically write these orders to the managed system or to create a ticket for manual provisioning.
For example, use the data from Identity Manager's Identity repository to fill in the AD's fields, such as users' display names based on their first names and last names from the repository. See the Create the Workforce Repository topic for additional information.
Identity Manager can also benefit from inbound connectors, that will write data to Identity Manager's central identity repository. While both inbound and outbound connectors allow data to flow both ways, they don't work in the same manner.
Technical principles​
Identity Manager's connectors all operate on the same basic principles. Technically speaking:
For example, consider connecting Identity Manager to an Active Directory (AD) instance.
  • a connector must be created, first as a named container which will include the connections and entity types related to one managed system;
    Create a connector named AD (so far, an empty shell).
  • A Connector is linked to an agent which acts as the go-between for Identity Manager's server and the managed system;
    The AD connector uses the provided SaaS agent.
  • A Connection describes the technology used that enables data to flow back and forth between Identity Manager and the managed system;
    Use a connection Directory/Active Directory to perform synchronization and automated provisioning, and a second connection Ticket/identitymanager to perform manual provisioning through Identity Manager.
You can find standard connections dedicated to one application (AD, Microsoft Entra ID, etc.), and generic connections to communicate with any application (CSV, Powershell, RobotFramework, SQL, etc.).
  • the shape of the extracted managed system's data is modeled by Entity Type (this documentation uses the term resource to refer to an entity type that has been instantiated);
    Create a single entity type AD - Entry which contains all the attributes that describe its resources, i.e. AD groups and users. The attributes include the department, the employee identifier, the manager, the group membership (member/memberOf), the dn, the parent dn, etc.
  • The intent of resources within the managed system is made clear by categorizing resources into Create a Resource Type. See the Categorize Resources topic for additional information.
    Categorize AD resources into distinct resource types: AD User (nominative) for basic accounts, which Identity Manager provisions automatically; AD User (administration) for sensitive administration accounts, which require manual provisioning through Identity Manager.
Connector Technical Schema
A connector requires at least one connection and one entity type.
When provisioning a managed system, the corresponding connector also needs at least one resource type.
Local vs. Saas agents: To simplify things, Identity Manager has made it possible to start configuring connectors without installing a local agent in your organization's network. Instead, you can use the agent integrated with Identity Manager's server in the Cloud (SaaS agent).
Participants and Artifacts​
For a given managed system, integrators may need the help of the application owner who knows the functional and technical details of the application.
InputOutput
Administrator account for the Development Environment (required) Identity repository (required) User Profile (required)Connector Connected System
See the Install the Development Environment, Create the Workforce Repository, and Configure a User Profile topics for additional information.
Create a Target Connector​
For one managed system, create a connector by proceeding as follows:
  1. Outside Identity Manager, Model the Data.
  2. Create the Connector for said managed system.
  3. Enable the technical transfer of data by creating and configuring Create a Connection.
  4. Set up Create an Entity Type to represent the data model decided upon in step 1.
Connector modification: The process for modifying a connector isn't so different from the process for creating a connector, as you mainly modify the fields specified during creation. However, a connector must be deactivated before modification to withdraw the connector's synchronization- and provisioning-related tasks from any jobs.
You can activate the connector again at any time using the same button.
Jobs Results Dashboard
Next Steps​
After you create the connector, you can start to Synchronize Data.
