Configure a Parametrized Role
How to reduce the number of roles in the model by configuring roles with parameters.
Overview​
The assignment of a role to a user gives them an entitlement, usually a group membership, thanks to a navigation rule. See the Create Roles in the Role Catalog topic for additional information.
Simple Role
To enable the assignment of all existing entitlements, the role model usually contains numerous roles.
For example, the SAP role can be given with slight differences according to the users' subsidiaries:
> Role Matrix
To reduce the number of roles, configure roles with parameters by inserting a criterion in the navigation rules. This way, instead of having as many roles as entitlements (left on the schema), you have way fewer roles (right on the schema).
With/Without Parameters
In the previous example, with a parameter on the subsidiary, the number of roles would be divided by three.
By extension, a composite role that assigns a parametrized single role is parametrized too.
This way, when assigning a parametrized role, a pop-up window is displayed where the parameter must be specified.
The same applies to type rules instead of navigation rules when assigning resource types instead of entitlements.
Configure a Parametrized Role​
Configure a parametrized role by proceeding as follows:
Step 1 – Create in XML a dimension corresponding to the parameter that will affect the role. See the Dimension topic for additional information.
For example, consider a case with many roles available on three different time slots: 8 hours a day, 12 hours a day, or 24 hours a day. Create a dimension for these time slots.
<Dimension Identifier="TimeSlot" DisplayName_L1="Time Slot" EntityType="Access_TimeSlot" ColumnMapping="10" IsExcludedFromRoleMining="true" />
Example - Role
Step 2 – Create a single role. See the Create a Role Manually topic for additional information.
Step 3 – Create one navigation rule linked to the role for each available value of the parameter. See the Create a Role Manually topic for additional information.
This example uses three navigation rules, one for each distinct time slot (dimension A):
Example - Rule
Ensure that the corresponding dimension is specified in the right DisplayEntityType in XML to be displayed in the UI.
For manually assigned roles, if a new dimension is added to the definition of the role, the assignment's dimension isn't recalculated, and therefore isn't propagated to calculate automatic assignments. Example scenario — Role A was created as a composite role with no parameters a long time ago. Role A was later updated to depend on the optional parameter X, and a single role rule was created to assign a single role B if a user had Role A and parameter X set to value Y. If a user already manually had the role A, even if its dimension X (for example its department, which could be calculated) was equal to value Y, got its permissions recalculated, that person wouldn't get the role B. Since the modification occurred after the assignment, the system treats the role as if it was assigned voluntarily with dimension X unset. However, if a user got role A assigned after the modification, and its dimension X was equal to value Y, then that user would get the role B.
Example - Role Parameter Required
Step 4 – Go back to the roles page to edit the single role from step 2, if needing to set the parameter required.
If you want Identity Manager to provide suggestions to set the parameter's value, then ensure that users' context rule specifies the dimension.
For example, with the Title dimension:
<ContextRule Identifier="Directory_User" DisplayName_L1="Directory_User" B0="Directory_UserRecord:Organization" <b>B1="Directory_UserRecord:Title"</b> B2="Directory_UserRecord:Site" B3="Directory_UserRecord:Site.Region.Country" B4="Directory_UserRecord:UserType.Category" ... Policy="Default" SourceEntityType="Directory_User" />
Verify the Parametrized Role​
To verify the process, request manually the parametrized role for a test user. Some additional pop-ups are displayed to set a value for the role's parameter. See the Request Entitlement Assignment topic for additional information.
In this example:
Example - Step 1
Example - Step 2
If the dimension is specified in the users' context rule, then Identity Manager will provide suggestions.
Example - Suggestion
For example, concerning the Title dimension mentioned above.
