Install the Production Agent
This guide shows how to install an agent separated from the server, for production environment. See the Architecture topic for additional information.
Overview​
Like all agents, the production agent aims to extract data from a given managed system, and transmit said data to the Identity Manager server. If necessary, the agent also enables the managed system's provisioning according to the orders computed by the Identity Manager server. See the Architecture topic for additional information.
Identity Manager solution can use several agents, each of them manages a given system. This section is about installing the agent managing the production environment.
Once agents are configured in addition to the default one provided by SaaS, you need to think about what agent to choose during each Create the Connector declaration. The appropriate agent has access to the managed system.
Requirements​
Ensure that all Agent requirements can be met before starting the installation of the production agent.
Requirements for the agent installation can change over the course of the project, according to the project purpose.
Encryption certificates​
Ensure that your encryption certificates are valid by checking their: expiration date; signatory; key size exceeding 2048; sha256 and not sha-1.
Server Manager​
Ensure that the device used for the installation has the Server Manager program.
Participants and Artifacts​
Integrators should have all the elements they need to operate.
InputOutput
Agent prerequisites (required)Production agent
Install the Production Agent​
Install the production agent by proceeding as follows:
  1. Create a Working Directory and ensure it contains the folders: Mails; Sources; Temp; Work.
  2. Configure the Agent's Settings via the web.config, appsettings.json and appsettings.agent.json files.
  3. Configure the local server to Install IIS via Server Manager.
  4. Configure the Pool and Site via IIS.
  5. Set the Working Directory's Permissions.
  6. Finalize the Installation.
Verify Agent Installation​
To verify the process:
  • ensure the website is accessible from IIS by clicking on Browse (in the menu on the right), and from your browser;
  • if logs are enabled, then stop the pool to ensure that no error is thrown;
  • perform from a local device agent-side actions such as sending test emails, reading, and/or writing inside working folders, or launching/scheduling agent-side tasks.
