Review an Unauthorized Account
How to remediate unauthorized accounts. The aim is to review the accounts whose assignments don't comply with the rules of the role model.
Overview​
Unauthorized accounts are considered as non-conforming assignments because no rule from Identity Manager's model can justify their actual assignment to an identity.
Participants and Artifacts​
InputOutput
Provision (required)Complying accounts
Review an Unauthorized Account​
Review an unauthorized account by proceeding as follows:
  1. Ensure that the Compute Role Model Task was launched recently, through the complete job on the Job Execution page:
    Home Page - Job Execution
Or through the connector's overview page Jobs > Compute Role Model.
Resource Type Jobs
  1. Get to the Resource Reconciliation page, accessible from the corresponding section on the home page.
    Home Page - Resource Reconciliation
  2. Select Unauthorized account as the Workflow State. Orphaned accounts appear with no owner.
    Resource Reconciliation Page
  3. Choose the default resource view or the property view with the top right toggle.
  4. Click the line of an account with an owner.
In the following example, the nominative LDAP account linked to the resource U40897 / Internal Users / acme / com has the owner Maxime Guillot with an 80% confidence rate.
Select Decision
The displayed confidence rate means that a rule actually assigned the account to the identity, but with a confidence rate too low to imply full automatic assignment. Approval will be required. See the Classify Resources topic for additional information.
The Resource Properties frame shows all the properties of the resources. They can be updated by clicking on the edit button. See the Reconcile a Property topic for additional information.
Edit Button
  1. Select the appropriate decision.
Decisions must be made with caution as they can't be undone.
  1. Click Confirm Account Deletion or Authorize Account according to the previous decision.
  2. Trigger the Provision by launching, on the appropriate connector's overview page Jobs > Generate Provisioning Orders, then, after this first task is done, Jobs > Fulfill.
    Resource Type Jobs
Use property view​
By default, non-conforming assignments are listed by resource. Click a resource to access the list of all unreconciled properties for said resource.
Resource View
It can be helpful to have the non-conforming assignments regrouped by property, as some of the changes can be similar, so very likely to be validated by the same user. This is why a property view can be enabled by clicking on the Property View toggle at the top right corner.
Property View
The review process is the same with both views. However with property view, reviewers don't click a given line, but choose a decision directly on the left of the property line.
Bulk Reconcile
Bulk keeping non-authorized accounts, by clicking on Bulk Reconcile then Approve Current Values, doesn't approve their unreconciled properties which will still be displayed on this screen.
Verify Review​
To verify the process, check that the changes you ordered appear on the corresponding user's View Permissions tab.
View Permissions Tab
