Toolkit for XML Configuration
The Netwrix Identity Manager (formerly Usercube) configuration is a set of XML files edited according the Identity Manager schema. The Recommendations part of this section explains how to set up an editing environment for the configuration.
Regardless of the editing space, the configuration persists in the Netwrix Identity Manager (formerly Usercube) database. It's this stored configuration that is used at runtime.
Use the Deploy Configuration Task tool to import a new version of the configuration (from the XML files set). Use the Usercube-Export-Configuration to export the current configuration (to a XML files set).
The Identity Manager project's integration cycle consists in developing a configuration by successive imports in a test instance.
