Application Settings
This section describes the settings available in the server's appsettings.json file, located in the server's working directory or in environment variables.
JSON files can contain any additional information that you might find useful. See the following example.
For example, to store the agent's address, can add:
appsettings.json
"<UsercubeAgent>": {
  "Url": "<http://localhost:1234>"
As Identity Manager doesn't know any object named Identity Manager Agent, its content will be ignored, but it can still be used to store information for human use.
The appsettings set allows the following attributes and sections:
NameTypeDescription
ApplicationUri requiredStringURI of the server to use in log messages, to communicate with the server in tasks, to allow certain redirect URIs. It must be the same as the agent's appsettings.json's ApplicationUri. Example: Replace code attributes enclosed with <> with a custom value before entering the script in the command line. appsettings.json {       …       "ApplicationUri": "usercubeserver.contoso.com:5000" }
EncryptionCertificate requiredEncryptionCertificateSettings to configure the encryption of specific files.
LicenseStringLicense key of the server. Example: Replace code attributes enclosed with <> with a custom value before entering the script in the command line. appsettings.json {       …       "License": "{"LicensedTo":"<Demo>","ValidTo":"<20120905>","IdentityQuota":"<10000>","Signature":"<…>"}" }
Agents optionalAgent ListList of agents' settings used to work on several environments. See the Architecture topic for additional information. This way, each Agent's URI/URL is configured without altering the database. Example: Replace code attributes enclosed with <> with a custom value before entering the script in the command line. appsettings.json {       …       "Agents": {             "Local": {                   "Uri": "<http://localhost:5010>"             },             …       } }
AppDisplay optionalAppDisplaySettings to override the application display XML configuration. See the App Display Setting topic for additional information. It is useful to change the application's theme and name without redeploying the whole configuration.
ApplicationInsights optionalApplicationInsightsSettings to plug to and configure the App Insights monitoring tool.
DataProtection optionalDataProtectionSettings to configure the encryption used for the authentication cookies and the anti-forgery tokens. The data protection can be configured to share the keys between several instances of Identity Manager's server, for example when deployed in a cluster where the servers don't have the same machine id.
DefaultPageSize optionalUIntDefault number of items returned when using squeries, if none specified in PageSize or in squery limit.
HstsPreload optionalAttribute default value: falseBooleanSets the preload parameter of the Strict-Transport-Security header. Preload isn't part of the RFC specification, but is supported by web browsers to preload HSTS sites on fresh install. Example: Replace code attributes enclosed with <> with a custom value before entering the script in the command line. <pre class="json"><code>*appsettings.json*<br /><br />{<br />  ...<br />  "HstsPreload":  true<br />}</code></pre>
InstallationDirectoryPath default value: Usercube-Server.exeStringPath of the installation directory. It is used to read other configuration files. Example: Replace code attributes enclosed with <> with a custom value before entering the script in the command line. appsettings.json {       …      "InstallationDirectoryPath":  "<C://identitymanagerContoso/Runtime>" }
MailSettings optionalStringSettings to configure the email service.
MaxActors default value: 20 maximum value: 50UIntThe maximum number of recipients who will be notified of the Workflow changes and can take action. If the number of recipients is exceeding the MaxRecipients value, then the actors will have the task assigned to them but they will not receive an email notification. In order for all actors to receive an email notification the MaxRecipients should be increased as well.
MaxPageSize optionalAttributeUIntIt represents the maximum number of items returned when using squeries.
MaxRamPercentageRoleMining optionalUIntOn-premises installations only. Limits memory usage for role mining operations as a percentage of available RAM (0-100). Identity Manager always estimates memory requirements before executing role mining. When this setting is greater than 0, operations are prevented if the estimated memory exceeds the specified percentage of available RAM. When not set or set to 0, no percentage-based limit is applied, though operations are still prevented if they would require more memory than total system RAM. Use this setting to prevent role mining from consuming excessive memory on shared servers. Example: appsettings.json { … "MaxRamPercentageRoleMining": 75 } See the Role Mining topic for additional information.
NotUseAgent default value: falseBooleanTrue to disable the use of the agent. See theArchitecture topic for additional information. Example: Replace code attributes enclosed with <> with a custom value before entering the script in the command line. appsettings.json {       …     "<NotUseAgent>":  true }
OpenIdClients optionalOpenIdClient ListList of hashed secrets used to override the plain-text secrets from the OpenIdClient XML configuration. See the OpenIdClient topic for additional information. This way, Identity Manager stores only hashed secrets, for security purposes. Each environment must have its own secret, distinct from the others. Example: Replace code attributes enclosed with <> with a custom value before entering the script in the command line. appsettings.json {       …     "OpenIdClients": {             "Job": {                   "<HashedSecret>": "<K7gNU3sdo+OL0wNhqoVWhr3g6s1xYv72ol/pe/Unols>"             },             "PowerBI": {                   "<HashedSecret>": "<7b8N2NWka5alDrjM7rFqf7+xqq9LIcT5jSoQ+1Ci2V0>"             }       } }
PowerBISettings optionalPowerBISettingsSettings to configure the API used by Power BI to access Identity Manager data.
Serilog optionalSerilogSettings to configure the logging service, complying to the Logger properties and structure. See the Monitoring topic for additional information. Example: Replace code attributes enclosed with <> with a custom value before entering the script in the command line. appsettings.json {       …     "Serilog": {             "WriteTo": ["Console"],             "MinimumLevel": {                   "Default": "Error",                   "Override": {                         "Usercube": "Information"                   }             }       } }
Swagger optionalSwaggerBy enabling Swagger you can visualize and interact with the API's resources without having any of the implementation logic in place. It is automatically generated from Identity Manager's API, with the visual documentation making it easy for back-end implementation and client-side consumption.
TempFolderPath default value: ../TempStringPath to the temporary folder which contains: - ExportOutput: directory storing data exported from connectors. - JobLogs: directory storing task instance logs. - Reports: directory storing generated reports. - Packages: directory storing the downloaded package logos. - PolicySimulations: directory storing the files generated by policy simulations. - ProvisioningCache.txt: file storing the clustered provisioning cache. When enabled, this file Use coordinate the API cache among clusters. - CorrelationCache.txt - RiskCache.txt - ExpressionCache.txt - scheduler.lock - connector.txt - container.reset.txt: file acting as a reset command for Identity Manager's server, i.e. any change to this file triggers the reset service, thus reloading all the services instantiated by the server. This path can be overridden by ResetSettings > FilepathResetService. - Mails: directory storing the email messages. This path can be overridden by ResetSettings > PickupDirectory. - Deployment These elements can be removed, but ensure to restart the server after doing so. Example: Replace code attributes enclosed with <> with a custom value before entering the script in the command line. appsettings.json {       …     "<TempFolderPath": "../Temp>" }
WorkFolderPath default value: ../WorkStringPath of the work folder which contains: - Collect: directory storing the CSV source files exported by connectors. - ProvisioningOrders: directory storing the orders generated by the server. - FulfillPowerShell: PowerShell provisioner's working directory. - FulfillRobotFramework: Robot Framework's provisioner working directory. - ExportCookies: directory storing the cookies used for incremental export. - Synchronization: directory storing the agent's data collection results. - Upload: directory storing the uploaded media like uploaded pictures, before they are inserted into the database. - appsettings.connection.json These elements must not be removed, because doing so may disrupt Identity Manager's execution after restarting. Example: Replace code attributes enclosed with <> with a custom value before entering the script in the command line. appsettings.json {       …     "<WorkFolderPath": "../Work>" }
Swagger​
Swagger is set using the attribute below.
NameTypeDescription
Enabled requiredBooleanTrue to enable Swagger. Example: appsettings.json {       …     "Swagger": {         "Enabled": false       }, } NOTE: recommend setting this to false for production environments.
Encryption Certificate​
This information can be set one of two ways:
  • As a Public Key Cryptography Standards (PKCS) #12 archive (also called Personal Information Exchange file or .pfx file) stored in the Agent's host file system. The archive contains both the public key certificate and the private key.
  • As a certificate from a Windows' certificate store identified by SubjectDistinguishedName or by Thumbprint. The Windows certificate also contains both the public key certificate and the private key.
  • Remember, Netwrix recommends using Windows' certificate store. A subject name can identify multiple certificates in the same Certificate Store since the Subject Name needs not to be unique. If there are multiple certificates identified by the subject name given in the appsettings, Identity Manager will use the first one. However it isn't possible to say exactly which certificate will be loaded first. The thumprint is unique among the certificates so it can help with for the certificate identification.
As a PFX file
For example:
    "EncryptionCertificate": {
        "File": "<C:/UsercubeAgentContoso/contoso.pfx>",
        "Password": "<YourPasswordHere>"
The archive is set using the following attributes:
NameTypeDescription
File requiredStringPKCS #12 archive path on the host file system.
Password optionalStringPKCS #12 archive password.
Storing a .pfx file password in plain text in a production environment is strongly discouraged. It should always be encrypted using the Usercube-Protect-CertificatePassword tool. See the Usercube-Protect-CertificatePassword topic for additional information.
NameTypeDescription
Password optionalStringPKCS #12 archive password. Storing a .pfx file's password in plain text in a production environment is strongly discouraged. It should always be encrypted using the Usercube-Protect-CertificatePassword.exe tool. See the Usercube-Protect-CertificatePassword topic for additional information.
As a Certificate in the Windows Store
For example:
         "DistinguishedName":"<UsercubeContoso>",
         "StoreLocation": "<LocalMachine>",
         "StoreName": "<AuthRoot>"
The Windows certificate is set using these attributes:
NameTypeDescription
DistinguishedName optionalStringSubjectDistinguishedName of the store certificate. It is required when Thumbprint isn't specified.
Thumbprint optionalStringThumbprint of the store certificate. It is required when DistinguishedName isn't specified.
StoreLocation requiredStringLocation of the relevant Windows certificate store: LocalMachine or CurrentUser.
StoreName requiredStringName of the relevant Windows certificate store.
Using Azure Key Vault
If the certificate is saved in Azure Key Vault, must define the certificate identifier and the Vault connection. See the Azure Key Vault topic for additional information.
"<EncryptionCertificate>": {
    "CertificateAzureKeyVault": "<CertificateIdentifier>"
Disabling file encryption
The encryption of specific files can be disabled via the following attribute:
NameTypeDescription
EncryptFile default value: trueBooleanTrue to encrypt specific files such as logs or temporary files. Example: Replace code attributes enclosed with <> with a custom value before entering the script in the command line. appsettings.json {       …       EncryptionCertificate": {             "EncryptFile": false       } }
Mail Settings​
For example:
appsettings.json
  "MailSettings": {
    "FromAddress": "<no-reply@acme.com>",
    "PickupDirectory": "<C:/identitymanagerDemo/Temp/Mails>",
    "UseSpecifiedPickupDirectory": true,
    "UseDefaultCredentials": false,
    "SecureSocketOption": "<StartTlsWhenAvailable>"
The mail settings details are:
NameTypeDescription
FromAddress requiredStringEmail address used as sender for Identity Manager's emails.
AllowedDomains optionalStringList of allowed domains, separated by ;.
CatchAllAddress optionalStringEmail address to be used as catchAll.
CatchAllCCAddress optionalStringEmail address to be used as CC catchAll.
Enabled default value: trueBooleanTrue to activate Identity Manager's email services.
EnableSsl default value: falseBooleanDEPRECATED: EnableSsl won't be supported in the future. specify a SecureSocketOption instead. To keep the same behavior as EnableSsl: True, use the setting SecureSocketOption: StartTls. True to encrypt communication with the SMTP server. To be used only when UseSpecifiedPickupDirectory is set to false.
MaxRecipients default value: 20StringThe maximum number of recipients visible in the "To", "CC" and "BCC" fields. Any additional recipient will be deleted automatically.
SecureSocketOption default value: AutoStringSpecifies the encryption strategy to connect to the SMTP server. If set, this takes priority over EnableSsl. None: No SSL or TLS encryption should be used. Auto: Allow the mail service to decide which SSL or TLS options to use (default). If the server doesn't support SSL or TLS, then the connection will not be encrypted. SslOnConnect: The connection should use SSL or TLS encryption immediately. StartTls: Elevates the connection to use TLS encryption immediately after reading the greeting and capabilities of the server. If the server doesn't support the STARTTLS extension, then the connection will fail and a NotSupportedException will be thrown. StartTlsWhenAvailable: Elevates the connection to use TLS encryption immediately after reading the greeting and capabilities of the server, but only if the server supports the STARTTLS extension. To be used only when UseSpecifiedPickupDirectory is set to false.
Host optionalStringName or IP address of the host used for SMTP transactions. It is required when UseSpecifiedPickupDirectory is set to false.
Password optionalStringPassword to be used with the user name as credentials.
PickupDirectory optionalStringPath of the folder where Identity Manager will save the email messages. It is useful and required when UseSpecifiedPickupDirectory is set to true.
Port optionalStringPort used for SMTP transactions. It is required when Host is defined.
UseDefaultCredentials default value: falseBooleanTrue to use in requests the default credentials instead of those from UserName and Password here.
UserName optionalStringUser name to be used with the user name as credentials.
UseSpecifiedPickupDirectory default value: falseBooleanTrue to save email messages to the folder specified in PickupDirectory instead of sending them to their recipients through the host specified in Host. Required when Host isn't defined.
Application Insights​
For example:
appsettings.json
  "ApplicationInsights": {
    "InstrumentationKey": "<AppInsights instance's key>"
The application insights details are:
NameTypeDescription
InstrumentationKey default value: nullStringKey linked to the AppInsights instance to which the server's logs, requests, dependencies, and performance are to be sent. See the Microsoft Create an Application Insights resource article for information on creating an instrumentation key.
The logs sent to AppInsights are configured through the Logger properties. See the Monitoring topic for additional information.
PowerBI Settings​
For example:
appsettings.json
  "PowerBISettings": {
    "PageSize": 500
The PowerBI Settings details are:
NameTypeDescription
PageSize default value: 1000Int32Size of the page containing the data returned by the API.
Data Protection​
For example:
appsettings.json
  "DataProtection": {
    "KeysPath": "</home/DataProtection>",
    "X509KeyFilePath": "<../identitymanager.pfx>",
    "X509KeyFilePassword": "<secret>"
The Data Protection details are:
NameTypeDescription
KeysPath default value: ../Work/DataProtectionStringPath of the location where the keys' descriptions are stored.
X509KeyFilePath optionalStringPath of the custom certificate used to protect the keys.
X509KeyFilePassword optionalStringPassword of the custom certificate used to protect the keys.
App Display​
For example:
appsettings.json
  "AppDisplay": {
    "PrimaryColor": "<#01CDE9>",
    "SecondaryColor": "<#EA6E1A>",
    "BannerColor": "<#EA6E1A>",
    "BannerTextColor": "<#ffffff>",
    "ApplicationNamePrefix": "<QA - >",
    "ApplicationName": "<USERCUBE>"
The App Display details are:
NameTypeDescription
ApplicationName optionalStringName of the application, visible on the application's tabs.
ApplicationNamePrefix optionalStringPrefix to be displayed before the application name.
BannerColor optionalStringHEX code of the color for the banner, i.e. the header displaying logo and navigation bar.
BannerTextColor optionalStringHEX code of the color for the banner's text.
PrimaryColor optionalStringHEX code of the color for the highlighted buttons.
SecondaryColor optionalStringHEX code of the color for the background of the authentication screen.
