Connection to the Database
The connection of Identity Manager's server to the database is set through the appsettings top-level ConnectionString and the AzureCredentials attributes:
NameDetails
ConnectionString requiredType String Description Identification token used to retrieve the connection information for the server to access Identity Manager's database in SQL Server. Note: must be compliant with SQL Server connection string syntax. See the Install the Server topic for additional information. Example{ "ConnectionString": "data source=.;Database=Usercube;Integrated Security=SSPI;Min Pool Size=10;encrypt=false;" }
ConnectionStringGovernor requiredType String Description Identification token used to retrieve the connection information to SQL Server Resource Governor which is a feature used to manage SQL Server's workload and system resource consumption. Info: Resource Governor enables specifying limits on the amount of CPU, physical /O, and memory that incoming application requests can use. Note: must be compliant with SQL Server connection string syntax. See the Install the Server topic for additional information. Note: all tasks and jobs use this connection string, when specified. Example{ "ConnectionStringGovernor": "data source=.;Database=Usercube;Integrated Security=SSPI;Min Pool Size=10;encrypt=false;" }
AzureCredentials requiredType Azure Credentials Description Settings used with the ConnectionString to access the database in SQL Server, hosted on Microsoft Entra ID (formerly Microsoft Azure AD).
AzureCredentials​
The database can be accessed one of two ways:
  • either by specifying User Id and password keywords directly in the connection string:
    For example:
"ConnectionString": "data source=.;Database=UsercubeContoso;User
Id=UsercubeServerContoso;Password=myPassword;Min Pool Size=10;encrypt=false;"
  • or, to avoid exposing the User Id and password in a connection string sent through the network, by using the built-in Microsoft Entra ID authentication method:
    For example:
"ConnectionString": "Server=tcp:<server-name>.database.windows.net,1433;Initial
Catalog=<database-name>;Persist Security
Info=False;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;"
See Microsoft's documentation for more details about authentication methods
The following example authenticates with ClientId and ClientSecret:
"ConnectionString": "Server=tcp:<server-name>.database.windows.net,1433;Initial Catalog=<database-name>;Persist Security Info=False;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;",
"AzureCredentials": {
"ClientId": "<client-id>",
"AADTenantId": "<AAD-tenant-id>",
"ClientSecret": "<client-secret>"
The following example authenticates with a pfx-stored public key certificate (password-protected pfx archive):
"EncryptionCertificate": {
"File": "<path-to-certificate>",
"Password": "<certificate-password>"
NameDetails
ClientId optionalType String Description Client ID obtained from Microsoft Entra ID when registering Identity Manager as an application.
AADTenantId optionalType String Description Microsoft Entra ID's tenant identifier obtained when registering ](https://learn.microsoft.com/en-us/entra/identity-platform/quickstart-register-app)Identity Manager as an application. Note: remember to set Identity Manager as owner of the targeted database when registering Identity Manager as an application in Microsoft Entra ID.
ClientSecret optionalType String Description Microsoft Entra ID's client secret used by Identity Manager to authenticate.Note: used only if EncryptionCertificate isn't specified.
EncryptionCertificate required, if ClientSecret isn't definedType Encryption Certificate Description Location of the certificate used by Identity Manager to authenticate, instead of the ClientSecret.
