Configure Okta
This guide shows how to configure the OIDC to set up the authentication to Identity Manager.
Create the Application​
On the Okta dashboard:
Add Application
Step 1 – Select the Applications section and click the Add Application button.
Create New App
Step 2 – Then click the Create New App button.
Create Native App
Step 3 – Select the platform Native app. The only sign-on method is the OpenID Connect. Click Create.
Step 4 – In General Settings, name your Application. You can also add a logo.
Step 5 – In the Configure OpenID Connect section, enter the connection redirection URL in the part: Login redirect URLs. To find this URL, take the Identity Manager application URL and add /signin-oidc. The Identity Manager disconnection redirection URL is also necessary. To construct it, take Identity Manager's URL and add /signout-callback-oidc at the end.
The Logout redirect URLs section is marked as optional but it is mandatory for Identity Manager.
Save Application
Configure the Client Credentials​
The client secret in Identity Manager is required for the OIDC connection. You must therefore configure this OIDC connection option in the application. In the Application Dashboard, click Edit in the Client Credentials section. Select the option Use Client Authentication and save the changes.
Client Credentials
Configure the Application Settings​
In the Application section, check the box Implicit (Hybrid) so that the connection with Identity Manager can operate correctly. Allow ID Token with implicit grant type is optional.
Application Section
Configure the appsettings.json​
To successfully configure the OpenId protocol, you can refer to the dedicated section in the detailed guide. See the End-User Authentication for additional information.
The following is an illustrative example of how to set up your appsettings.json file.
appsettings.json
  "OpenId": {
    "Enabled": true,
    "Okta": {
      "AuthenticationScheme": "Okta Authentication",
      "Authority": "https://your-domain.okta.com/oauth2/default",
      "ClientId": "Your Client ID",
      "ClientSecret": "Your Client Secret",
      "DisplayName": "Okta Display Name",
      "NameClaimType": "https://schemas.xmlsoap.org/ws/2005/05/identity/claims/upn",
      "SaveToken": true
