RSA Encryption
Identity Manager provides a few options to protect sensitive data via RSA encryption.
Overview​
Sensitive data can be RSA encrypted by using Identity Manager's tools:
The file encryption tool should be used only on files that contain only plain text values, not already encrypted ones.
Once encrypted, sensitive values can be added to the appsettings.encrypted.json and appsettings.encrypted.agent.json files. Identity Manager will read first the values from the encrypted appsettings files, before reading those from the usual non-encrypted appsettings files.
These methods require an X.509 public key certificate (the same for the encrypted appsettings files and the tools).
The value encryption tool Use encrypt specific values to be added to the encrypted appsettings files without having to encrypt the whole files again.
Focus on the Encrypted Appsettings Files​
The appsettings.encrypted.json and appsettings.encrypted.agent.json files contain respectively the appsettings.json and appsettings.agent.json files' sensitive setting values which are protected by RSA encryption.
These files follow the exact same structure as the Agent Configuration.
Read the Encrypted Files​
Identity Manager can use an RSA decoding algorithm fed by a public-key certificate to read the encrypted application settings.
This requires the usual appsettings files to have UseEncryptedAppsettings set to true. See the following section.
appsettings.json and/or appsettings.agent.json
"EncryptionCertificate": {
"File": "./identitymanager.pfx",
"Password": "secret",
"UseEncryptedAppsettings": true
This way, values from the encrypted file take priority over the values from the non-encrypted appsettings files.
For example, if Password exists in both the encrypted file and the non-encrypted file, then the value from the encrypted file is used.
