Azure Key Vault
Prerequisites​
First, NETWRIX recommends reading:
Compatible Settings​
Every key from appsettings.agent.json that has a string value can be saved as a secret into Microsoft Entra ID (formerly Azure AD) Key Vault. See the appsettings.agent topic for additional information.
Check the examples in connectors' credential protection sections. See the ServiceNow topic for additional information.
Write Settings to the Vault​
After creating the Azure Key Vault, open its page on Azure's portal and add a secret.
The important part of adding a secret in Azure Key Vault is defining its name and value:
  • As secrets' names can only contain alphanumeric characters and double dashes (--) as separator, the keys from the appsettings.agent.json file must contain only alphanumeric characters too;
  • Secrets's values are the values associated with the key in the JSON file.
For example, for the Active Directory:
  "Connections": {
    "ADExport": {
      "Servers": [{
          "Server": "<paris.contoso.com>",
          "BaseDN": "<DC=paris,DC=com>"
          "Server": "<marseille.contoso.com>",
          "BaseDN": "<DC=defense,DC=marseille,DC=com>"
      "AuthType": "<Basic>",
      "Login": "<login123>",
      "Password": "<YourPasswordHere>",
      "Filter": "(objectclass=*)",
      "EnableSSL": "false",
To save the log in to Azure Key Vault, create a secret whose name and value are respectively <Connections--ADExport--Login> and <login123>.
To save the second server, create a secret whose name and value are respectively <Connections--ADExport--Servers--1--Server> and <marseille.contoso.com>.
tip
Remember, the index of the first element is 0.
This way, values from the Azure Key Vault take priority over the values from the appsettings files.
For example, if Login exists in both Azure Key Vault and appsettings.agent.json, then the value from Azure Key Vault is used.
Configure Usercube​
Netwrix Identity Manager (formerly Usercube) uses the default Azure credentials to connect to the vault. Since the implementation of default Azure credential is controlled by Microsoft see the Default Azure Credential page for additional information.
For example:
*appsettings.json*
"AzureKeyVault": {
"Vault" : "https://usercubekeyvault.vault.azure.net/",
"ConnectionString": "RunAs=App;AppId={<dcb9b3a4-159c-45d8-93d5-8d6d677de4a7>};TenantId={<7a06f56c-47a8-469b-b0c0-089ec0666bd1>};AppKey={<Ju4m3BWA_U~s9XVlI_btgydJ8w5wY.iD.L>}"
NameDetails
Vault
required
Type
string
Description
DNS Name found on the page of the vault in Azure's portal.
Info: usually in the format https://yourVault.vault.azure.net/.
ConnectionString
default value: null
Type
string
Description
Identification token used to retrieve the various connection keys found in the Azure Key Vault. It concatenates a series of options defining the authentication to Azure Key Vault.
null - the connection is established with the current user.
Warning: this user must be connected to the Microsoft Entra ID (formerly Azure Active Directory) instance and to the correct tenant.
Otherwise, Identity Manager gets the token from Microsoft Entra ID via:
RunAs=App - a managed identity.
Warning: connecting via a managed identity must be enabled on Azure's App Service.
RunAs=App;AppId={ClientId of user-assigned identity} - a user-assigned identity.
RunAs=App;AppId={TestAppId};KeyVaultCertificateSecretIdentifier={KeyVaultCertificateSecretIdentifier} - the application and a certificate's secret, for custom services authentication.
RunAs=App;AppId={AppId};TenantId={TenantId};CertificateThumbprint={Thumbprint};CertificateStoreLocation={LocalMachine or CurrentUser} - a certificate with a thumbprint on TenantId.
RunAs=App;AppId={AppId};TenantId={TenantId};CertificateSubjectName={Subject};CertificateStoreLocation={LocalMachine or CurrentUser} - a certificate with a DN on TenantId.
RunAs=App;AppId={AppId};TenantId={TenantId};AppKey={ClientSecret} - a secret.
