Usercube-Update-EntityPropertyExpressions
This tool is used to recompute the values of all properties defined via expressions (C#, etc.), usually to prepare for a connector's synchronization.
Examples​
The following example updates the property expressions of the database defined by the connection string, for all entity types.
**./Usercube-Update-EntityPropertyExpressions.exe --database-connection-string "data source=.;Database=Usercube;Integrated Security=SSPI;Min Pool Size=10;encrypt=false" -a**
Arguments​
Argument NameDetails
--batch-select-size (-q) default value: 10000Type Int32 Description Batch size for SELECT queries. Query batching performance guide.
--batch-update-size (-c) default value: 20000Type Int32 Description Batch size for UPDATE queries. Query batching performance guide.
--database-connection-string requiredType String Description Connection string of the database.
--all-entityType (-a) optionalType No Value Description Applies the tool to all entity types.
--batch-size (-q) default value: 5000Type Int32 Description Batch size for queries. Query batching performance guide.
--dirty optionalType No Value Description Applies the tool incrementally by applying it only to resources marked as dirty, i.e. recently modified.
--entitytype-list optionalType String List Description List of entity types that the tool is to be applied to. Note: required when --all-entityType isn't specified.
--resource-identity-property optionalType String Description Property used to override the resource identity property set in the Select User by Identity Query Handler Setting.
