Usercube-Manage-History
This tool optimizes the data history stored in the database, reducing its size and enhancing database performance.
The inner workings of this executable are based on the ValidFrom and ValidTo attributes that specify the validity period of a given assignment. These attributes are inside the following tables which are the tables actually purged: ur_resources; ur_resourcelinks; up_assignedcompositeroles; up_assignedsingleroles; up_assignedresourcenavigations; up_assignedresourcetypes.
Protected resources​
When purging ur_resources, resources that are still referenced by other product data (assignments, workflows, certifications, etc.) are treated differently from fully unreferenced resources:
  • Referenced (protected): the most recently expired row is kept, with only Id, Type, ValidFrom, ValidTo and DisplayName_L* retained.
  • Unreferenced: all expired rows are deleted entirely.
This preserves a traceable record of the resource for audit purposes.
Examples​
Purge before a period
To clean the database periodically, it can be purged of all the history older than a given period of time.
The following example deletes all the history from the database that is more than 12-month old:
./Usercube-Manage-History.exe <b>--purge-before-months 12</b> --database-connection-string "data source=.;Database=Usercube;Integrated Security=SSPI;Min Pool Size=10;encrypt=false;"
Purge before a date
The database can be purged of all history older than a given date.
The following example deletes all the history from the database older than May 26th 1993:
./Usercube-Manage-History.exe <b>--purge-before-date 19930526</b> --database-connection-string "data source=.;Database=Usercube;Integrated Security=SSPI;Min Pool Size=10;encrypt=false;"
Optimize
The database's history can be optimized by removing intermediate versions based on their age, for example keeping only one version the last week, one per month the last 6 months and then one per year for 3 years.
The following example reduces the history from the database, keeping at most one history version per interval. Keep one version per day (1440 minutes) in the last 7 days, then one version per month (43920 minutes) in the last 6 months before the previously defined period, then one version per year (525960 minutes) in the last 2 years before the previously defined periods.
Schema - Optimize
For each period, if there is more than one version (i.e. ValidFrom is inside the interval), the versions are merged in the following way:
  • The latest version is kept
  • The oldest date is kept (that is, in the database, the ValidFor is equal to the one of the oldest version in the considered period).
./Usercube-Manage-History.exe <b>--optimize "1440:7 43920:6 525960:2"</b> --database-connection-string "data source=.;Database=Usercube;Integrated Security=SSPI;Min Pool Size=10;encrypt=false;"
To configure a time period when there is no purge and all history is kept as is, specify a short duration that allows a single change, for example only one minute. The following example copies the previous one, in addition to keeping all changes of the last 6 hours (360 minutes): --optimize 1:360 1440:7 43920:6 525960:2.
Clean duplicates
As given data can have several versions in the database, redundant rows can be deleted and replaced with one row that covers the consolidated time range.
The following example remove all duplicates in the database.
**./Usercube-Manage-History.exe <b>--clean-duplicates</b> --database-connection-string "data source=.;Database=Usercube;Integrated Security=SSPI;Min Pool Size=10;encrypt=false;"**
The following example remove all duplicates induced by the pwdLastSet property.
./Usercube-Manage-History.exe <b>--clean-duplicates</b> --excluded-resource-columns "pwdLastSet" --database-connection-string "data source=.;Database=Usercube;Integrated Security=SSPI;Min Pool Size=10;encrypt=false;"
Solicit memory rather than the database
To reduce the database load, the tool's optimizations can be made via the local device's memory.
The following example deletes all the history from the database that is more than 12-month old, the optimizations being computed in memory instead of in the database:
./Usercube-Manage-History.exe <b>--purge-before-months 12</b> <b>--in-memory</b> --database-connection-string "data source=.;Database=Usercube;Integrated Security=SSPI;Min Pool Size=10;encrypt=false;"
Arguments​
Argument NameTypeDescription
--clean-duplicates optionalNo ValueRemoves duplicate historical data.
--entity-type required if --excluded-resource-columns is setStringWhen using <b>--clean-duplicates</b> option, defines the entity type (Id or Identifier) that should have its duplicates removed from the UR_Resources table.
--excluded-resource-columns required if --entity-type is setString listWhen using <b>--clean-duplicates</b> option, defines the list of column names (the name of the columns in the UR_Resources table, or the Identifier of the corresponding um_entityproperty) to exclude when comparing rows of UR_Resources table.
--in-memory default value: FalseNo valuePerforms optimizations in memory instead of the database. It implies heavy memory consumption but light SQL load.
--optimize optionalString listReduces the history and optimizes the versions that are kept based on the precision given through ranges in the argument. A range is specified by a duration in minutes followed by the number of occurrences. For example 60:10 defines a range of 60 minutes repeated 10 times, or 10 snapshots repeated at 60 minute intervals. For each interval, at most one version is kept in the history. The intervals are evaluated in the given order from now, backwards. In the previous example, it means the more recent versions are kept with a high precision (one per day initially), then with lesser and lesser precision (one per month and then one per year). If the data has not changed over an interval, no optimization can be done.
--purge-before-date optionalStringDeletes all the history older than the given date in the yyyyMMdd format. For ur_resources, referenced resources are kept; see Protected resources.
--purge-before-months optionalStringDeletes all the history older than the given number of months. For ur_resources, referenced resources are kept; see Protected resources.
--database-connection-string requiredStringConnection string of the database.
The available actions (clean duplicates; purge; optimize) are all optional, but at least one must be used in the executable command.
