Usercube-Export-Excel
Examples​
Exporting a file respecting the default parameters​
Consider the file C:/identitymanagerContoso/Sources/hr_example.xlsx with UTF8 encoding, it can be exported using these command's arguments:
--raw-files-path C:/identitymanagerContoso/Sources/hr_example.xlsx --not-incremental --connection-identifier HREXAMPLE --output-path C:/identitymanagerContoso/Temp/ExportOutput
The output files will be located in C:/identitymanagerContoso/Temp/ExportOutput/. Their number corresponds to the number of sheets in the XLSX file and they would be labeled: HREXAMPLE_0.csv, HREXAMPLE_1.csv, ... HREXAMPLE_n-1.csv where n corresponds to the amount of spread sheets of the XLSX file. The encoding is UTF8 and the separator is ,.
Skipping some file's lines​
The possibility to skip lines is made available using the --lines-to-skip argument:
--raw-files-path C:/identitymanagerContoso/Sources/hr_example.xlsx --not-incremental --connection-identifier HREXAMPLE --output-path C:/identitymanagerContoso/Temp/ExportOutput --lines-to-skip 10
As a consequence, the exported file would include the content of the XLSX file without the ten first lines.
Regex in file name​
Considering a generated file following the regex: C:/identitymanagerContoso/Sources/hr_example(.*?).xlsx, for instance C:/identitymanagerContoso/Sources/hr_example5fH8g1.xlsx, if several files match with the regex, the executable would use the most recent one.
The regex can be included in the filename and would need to be precised using the --is-regex argument:
--raw-files-path C:/identitymanagerContoso/Sources/hr_example(.*?).xlsx --not-incremental --connection-identifier HREXAMPLE --output-path C:/identitymanagerContoso/Temp/ExportOutput --is-regex
Choosing value to trim​
It's possible to precise characters to trim using the --values-to-trim argument:
--raw-files-path C:/identitymanagerContoso/Sources/hr_example.xlsx --not-incremental --connection-identifier HREXAMPLE --output-path C:/identitymanagerContoso/Temp/ExportOutput --values-to-trim e
The CSV output file will see every words beginning and ending by "e" (lower-case, this process is case sensitive) removed of this letter.
Ignoring particular sheets​
The --sheets-ignored argument allows the user to specify for each sheet if it should be ignored during the export. More precisely, a list of true or false arguments should be specified respectively to the sheets. Let's say the C:/identitymanagerContoso/Sources/hr_example.xlsx file possesses three sheets, to export the first and the last ones the arguments would be:
--raw-files-path C:/identitymanagerContoso/Sources/hr_example.xlsx --not-incremental --connection-identifier HREXAMPLE --output-path C:/identitymanagerContoso/Temp/ExportOutput --sheets-ignored false true true false
Thus, two CSV files would be created corresponding to the chosen ones: HREXAMPLE_0.csv and HREXAMPLE_3.csv.
Path Duality and the Not-Launch-Export System​
The export executable might be used for a complete or an incremental synchronization. Thus, it possesses two paths that could be precised - depending on the case - with the --raw-files-path for complete synchronizations argument or the --path-incremental for incremental ones.
Ultimately, the --not-incremental argument defines the export behavior: if present it means a complete synchronization should be performed and the --raw-files-path argument must be precised; if missing an incremental synchronization would be performed using --path-incremental.
It means that if the user provide the --not-incremental argument and no --raw-files-path, or if the user doesn't provide --not-incremental nor --path-incremental, the export will not be launched to prevent any issue (complete data for an incremental synchronization for instance). The --force-complete argument bypasses this safeguard: during the initialization job for example, to perform a complete synchronization, even for Excel connections with only an incremental path.
Arguments​
Argument NameDetails
--not-incremental optionalType No Value Description Specifies the synchronization mode, its presence meaning complete, its absence incremental.
--is-regex optionalType No Value Description The file's name is a regex to find the last generated corresponding file.
--connection-identifier optionalType String Description Connector's connection identifier. The output file will have this identifier as name.
--output-path requiredType String Description Output path for the files generated by the export.
