Usercube-Export-Csv
Examples​
Exporting a file respecting the default parameters​
Consider the file C:/identitymanagerContoso/Sources/hr_example.csv with , as separator and UTF8 encoding, it can be exported with the command:
--raw-files-path C:/identitymanagerContoso/Sources/hr_example.csv --ignore-cookies --connection-identifier HREXAMPLE --output-path C:/identitymanagerContoso/Temp/ExportOutput
The output file will be located in C:/identitymanagerContoso/Temp/ExportOutput/HREXAMPLE.csv and the content will be a copy of hr_example.csv's one and an UTF8 encoding.
Define a separator​
Consider the file C:/identitymanagerContoso/Sources/hr_example.csv with ; as separator.
As , is considered to be the default separator, set it:
--raw-files-path C:/identitymanagerContoso/Sources/hr_example.csv --ignore-cookies --connection-identifier HREXAMPLE --output-path C:/identitymanagerContoso/Temp/ExportOutput --separator ;
The result's content will be the same but with , as separator.
Use a regex file name​
Consider that you deal with a generated file that follows the regex: C:/identitymanagerContoso/Sources/hr_example(.*?).csv, for example C:/identitymanagerContoso/Sources/hr_example5fH8g1.csv. If several files match with the regex, the executable uses the last one that was generated.
You can put your regex and precise that it is one with the --regex argument:
--raw-files-path C:/identitymanagerContoso/Sources/hr_example(.*?).csv --ignore-cookies --connection-identifier HREXAMPLE --output-path C:/identitymanagerContoso/Temp/ExportOutput --regex
Use the Path Duality and the Not-Launch-Export System​
In a larger context, the export might be used for complete or incremental synchronization. That is why it has two paths: --raw-files-path for complete synchronizations, --path-incremental for incremental ones.
In the export's scope, it only means one thing, what path must be used depends on --ignore-cookies: its presence meaning a complete synchronization context with --raw-files-path; its absence indicating an incremental context with --path-incremental.
It means that if the user gives --ignore-cookies and not --raw-files-path, or if they give neither --ignore-cookies nor --path-incremental, the export will not be launched to prevent any problem (complete data for an incremental synchronization for example). The --force-complete argument bypasses this security: in the product, it is used for the initialization job to perform a complete synchronization, even for CSV connections with only an incremental path.
Arguments​
Argument NameDetails
--connection-identifier optionalType String Description Connector's connection identifier. The output file will have this identifier as name.
--output-path requiredType String Description Output path for the files generated by the export.
--ignore-cookies optionalType No Value Description Specifies the synchronization mode, its presence meaning complete, its absence incremental.
--regex optionalType No Value Description The file name is a regex to find the last generated corresponding file.
--separator optionalType String Description Defines the separator if different than ,.
