Usercube-Encrypt-File
In Identity Manager, files are encrypted by default. This tool encrypts an input file or the InputConsole of a Powershell program or file to save it as an encrypted output file. This task can't be configured in the configuration.
Examples​
Launch the tools with input console (powershell script)​
The following example, used in a Powershell script, decrypts the files specified by the csvResult variable and saves the result in the location specified in resultsFile. The encryption is made using the certificate's thumbprint, store location and store name.
$csvResult | & ./Usercube-Encrypt-File.exe --file-cert-thumbprint $certificateThumbprint --file-cert-store-location $certificateStoreLocation --file-cert-store-name $certificateStoreName --output-path $resultsFile
Arguments​
Argument NameDetails
--files (-f) optionalType String Description List of all the files to encrypt. Note: required when the entry is made of files.
--output-path (-o) optionalType String Description Output path to save the encrypted files or input console.
--file-cert-thumbprint optionalType String Description Thumbprint of the certificate when the certificate is in the store.
--file-cert-dn optionalType String Description Subject Distinguished Name of the certificate when the certificate is in the store.
--file-cert-store-location optionalType String Description Store location of the certificate when the certificate is in the store.
--file-cert-store-name optionalType String Description Store name of the certificate when the certificate is in the store.
--file-cert-file optionalType String Description File path of the certificate when the certificate is in a PFX file.
--file-cert-password optionalType String Description Password of the certificate when the certificate is in a PFX file.
