Usercube-EasyVistaTicket-UpdateFulfillmentState
The use of this executable supposes a previous use of the Usercube-Fulfill-ToEasyVistaTicket executable.
Usercube-Fulfill-ToEasyVistaTicket creates tickets in an EasyVista instance: Usercube-EasyVistaTicket-UpdateFulfillmentState sets the fulfillment state of the corresponding assigned resource types in Identity Manager for tickets that are closed (Executed) or canceled (Error).
Examples​
Connector specified​
In this example, for all resource types that have a target entity type of the connector EasyVista, the fulfillment state of the corresponding assigned resource types is set.
Resource types specified​
In this example, for the resource types EasyVista_NominativeUser and EasyVista_Administrator, the fulfillment state of the corresponding assigned resource types is set.
Arguments​
Argument NameDetails
--api-client-id requiredType String Description Login used to authenticate to the server. Every request from agent to server needs to be authenticated with anOpenIdClient Connect ClientId/Secret pair, linked to a profile with the relevant permissions.
--api-secret requiredType String Description Password used to authenticate to the server. Every request from agent to server needs to be authenticated with an OpenIdClient Connect ClientId/Secret pair, linked to a profile with the relevant permissions.
--api-url requiredType String Description URL of Identity Manager server.
--connector required if --resource-typesis not givenType String Description Id or Identifier of the resource types' connector to update the fulfillment state.
--resource-types required if --connectoris not givenType String List Description Id or Identifier of the resource types to update the fulfillment state.
--certificate-identifier optionalType String Description Unique key used to retrieve the certificate in Azure Key Vault.
--vault optionalType String Description Vault uri.
--vault-connection-string optionalType String Description Connection string to connect to Azure Key Vault.
--batch-size default value: 1000Type Int32 Description Number of provisioning orders to wait between each progress report.
--task-instance-id optionalType String Description Id of the task instance which have launch the exe in a job context (for log purposes).
