Usercube-Compute-CorrelationKeys
This tool is used to compute the values of all correlation keys.
Examples​
The following example computes the correlation keys of the database defined by the connection string, for all entity types.
**./Usercube-Compute-CorrelationKeys.exe --database-connection-string "data source=.;Database=Usercube;Integrated Security=SSPI;Min Pool Size=10;encrypt=false" -a**
Arguments​
Argument NameDetails
--batch-size (-q) default value: 5000Type Int32 Description Batch size for queries. Query batching performance guide.
--database-connection-string requiredType String Description Connection string of the database.
--all-entityType (-a) optionalType No Value Description Applies the tool to all entity types.
--dirty optionalType No Value Description Applies the tool incrementally by applying it only to resources marked as dirty, i.e. recently modified.
--entitytype-list optionalType String List Description List of entity types that the tool is to be applied to. Note: required when --all-entityType isn't specified.
--resource-identity-property optionalType String Description Property used to override the resource identity property set in SelectUserByIdentityQueryHandler.
