Usercube-Check-ExpressionsConsistency
This tool is used to check the C# expressions consistency.
Examples​
The following example checks the C# expressions compatibility with Identity Manager.
.\Usercube-Check-ExpressionsConsistency.exe --database-connection-string "data source=.;Database=UsercubeV5demo;Integrated Security=SSPI;Min Pool Size=10;Encrypt=false" --output-path "C:\UsercubeDemo\Dump"
In case errors are found they will be displayed as:
In Custom/User/Directory User Connector.xml(12), Method "System.Linq.Enumerable.MaxBy" cannot be called on entities.
Arguments​
Argument NameTypeDescription
--database-connection-string requiredStringSQL database connection string.
--output-pathStringFull path of the folder in which the file containing expression compilation errors will be saved.
