Manual Ticket and CUD Resources
Opens manual provisioning tickets in Identity Manager.
Package CharacteristicsValue
Display NameTicket/identitymanager And Create/Update/Delete resources
IdentifierUsercube.UpdateManualProvisioningTicket@0000001
ExportNONE
FulfillUsercube-UpdateManualProvisioningTicket.dll and Usercube-Update-FulfillmentStates.dll
Has Incremental ModeFalse
PublisherIdentity Manager
Virtual Resources​
This package allows to create tickets in the Manual Provisioning screen.
After the validation of the ticket, the state of the resource will be Executed. If a synchronization is available for the system manually fulfilled, the state could change to Verified if the synchronized data are the ones expected. If the external system can't be synchronized, Identity Manager offers the possibility to create virtual resources. It means that the data isn't provided by a synchronization, but the validation of the ticket is trusted in the manual provisioning screen. The resources are created accordingly as if they were coming from an external system.
Rights for CUD Resources​
If this package is used from the interface, the necessary rights will be automatically added. If this package is used from the XML configuration, some rights will need to be added to allow the creation, update, or deletion of virtual resources.
Example​
Here is an example for an entity type called MyTicketEntity:
<AccessControlRule Profile="Administrator" EntityType="MyTicketEntity" Identifier="Administrator_MyTicketEntity" DisplayName_L1="Administrator_MyTicketEntity"> <Entry Permission="/Custom/Resources/MyTicketEntity/Query" CanExecute="true" /> <Entry Permission="/Custom/Resources/MyTicketEntity/Create" CanExecute="true" /> <Entry Permission="/Custom/Resources/MyTicketEntity/Update" CanExecute="true" /> <Entry Permission="/Custom/Resources/MyTicketEntity/Delete" CanExecute="true" /></AccessControlRule>
