Generic SQL
Exports data from a SQL database.
| Package Characteristics | Value |
| Display Name | Database/Generic SQL |
| Identifier | Usercube.SQL@0000001 |
| Export | Usercube-Export-Sql.dll |
| Fulfill | NONE |
| Has Incremental Mode | False |
| Publisher | Identity Manager |
When creating a connection to a database which isn't handled by Identity Manager's packages, you'll need to fill in the ProviderDllName and ProviderClassFullName properties of the Sql connector using the procedure given in the example.
