SharedFolders
This connector exports users and permissions from Windows shared folders.
This page is about Shared Folders.
Package: Storage/Shared Folders
Overview​
Also known as UFA (Identity Manager Folder Access), use this connector to scan the access rights assigned to folders and files in computers and networks which comply with the Windows File Security and Access Rights systems.
Prerequisites​
Implementing this connector requires an account with the permissions:
  • to access all relevant folders and files and read their entitlements;
  • Log on as a batch job in the local group policy, when the connector's authentication mode is batch.
    SharedFolder - Permission for Batch Authentication
Export​
This connector scans shared folders to export their content to CSV files.
Configuration​
This process is configured through a Connection in the UI and/or the XML configuration, and in the *appsettings.agent.json* > Connections section:
"Connections": {
"<ConnectionIdentifier>": {
  • be unique.
  • not begin with a digit.
The following example reads 12 levels of folders in the folders R&D_Projects and Management in the network OfficeNetwork and in C:/. Only read entitlements about folders and don't have access rights to the entitlements associated with the SIDs S-1-3-2-4 and S-5-7-6-8. Use the service account account@example.com with its related password and domain, and interactive connection:
"Connections": {
"SharedFolderExport": {
"InputDirectories": ["OfficeNetwork/R&D_Projects", "OfficeNetwork/Management", "C:/"],
"OnlyDirectoryScan": "true",
"LevelOfScan": "12",
"ListOfSIDToAvoid": ["S-1-3-2-4", "S-5-7-6-8"],
"Login": "account@example.com",
"Password": "accountexamplepassword",
"Domain": "Example",
"Interactive": true
Setting attributes​
NameDetails
InputDirectories requiredType String List Description Paths of the folders to be scanned.
Domain optionalType String Description Domain of the account used to access files and read their access rights.
Interactive default value: FalseType Boolean Description True to set authentication as interactive, False to set it as batch.
LevelOfScan optionalType Int32 Description Number of file and folder levels to be scanned. By default, it scans the whole folder tree for each input directory.
ListOfSIDToAvoid optionalType String List Description SIDs (users or groups) to exclude from the scan.
OnlyDirectoryScan default value: FalseType Boolean Description True to scan only folders' entitlements and not files', False to scan all.
Login optionalType String Description Login of the account used to access the files and folders. Note: when not specified and Password neither, then the account running Identity Manager will be used. Note: if Domain is null, then Login must be set in the User Principal Name (UPN) format.
Password optionalType String Description Password of the account used to access the files and folders. Note: when not specified and Login neither, then the account running Identity Manager will be used.
Output details​
This connector is meant to generate to the Application SettingsExport Output folder the following CSV files:
  • <connectionIdentifier>_ACE.csv, with the following columns:
    • key: concatenation of Right, Path and OwnerSID;
    • Path: path of the folder or file;
    • Right: entitlement among the following, listed from weakest to strongest: ListDirectory / ReadData / CreateFiles / WriteData / AppendData / CreateDirectories / ReadExtendedAttributes / WriteExtendedAttributes / ExecuteFile / Traverse / DeleteSubdirectoriesAndFiles / ReadAttributes / WriteAttributes / Write / Delete / ReadPermissions / Read / ReadAndExecute / Modify / ChangePermissions / TakeOwnership / Synchronize / FullControl
    • AllowOrDeny: 0 (or false) if the entitlement is allowed, 1 (or true) if it is denied;
    • OwnerSID: SID of the entitlement's owner.
  • <connectionIdentifier>_PathInformations.csv, with the following columns:
    • Path;
    • ParentPath: path of the file's or folder's parent folder;
    • BlockInheritance: true if the file or folder blocks entitlement inheritance in the tree;
    • Hierarchy: hierarchy in the scanned tree.
  • <connectionIdentifier>_SID.csv, with only one column SID.
Fulfill​
There are no fulfill capabilities for this connector.
Authentication​
Password reset​
This connector doesn't reset passwords.
Credential protection​
AttributeNaming Convention for the Key in Azure Key Vault
DomainConnections--<identifier>--Domain
InteractiveConnections--<identifier>--Interactive
LevelOfScanConnections--<identifier>--MembersFile
ListOfSIDToAvoidConnections--<identifier>--ListOfSIDToAvoid
LoginConnections--<identifier>--Login
OnlyDirectoryScanConnections--<identifier>--OnlyDirectoryScan
PasswordConnections--<identifier>--Password
InputDirectoriesConnections--<identifier>--InputDirectories
  • A Connection able to store Active Directory's Login and Password.
Protected attributes are stored inside a safe in cyberark, into an account whose identifier can be retrieved by Identity Manager from *appsettings.<b>cyberark</b>.agent.json*.
For example:
"Connections": {
"Login": "SharedFolderSettings",
"Password": "SharedFolderSettings"
