SCIM
This connector exports and fulfills entities from/to a SCIM compliant application.
This page is about:
  • Custom/SCIM
  • CRM/Salesforce
  • Messaging/Slack
  • PAM/cyberark
Package: Custom/SCIM
Package: CRM/Salesforce
Package: Messaging/Slack
Package: PAM/cyberark
Overview​
System for Cross-domain Identity Management (SCIM) is a Request for Comments (RFC) standard. It describes a REST API with specific endpoints to get and set data in a web application for IGA purposes. It allows an identity provider to manage the web application's accounts. For more details about SCIM and RFC, see the IETF document.
Similarly to the Salesforce REST-based API, SCIM for Salesforce enables reading and writing attributes, but writes to a smaller subset. For example, the following properties are manageable by the Salesforce REST-based API but not SCIM: PermissionSetGroup, PermissionSetLicense, UserPermissionsKnowledgeUser, UserPermissionsInteractionUser, UserPermissionsSupportUser, CallCenterId, SenderEmail.
See the Salesforce's documentation for additional information.
Prerequisites​
Implementing this connector requires the web application that you want to synchronize to implement SCIM Version 2.0 or later.
The implementation of the Salesforce connector requires the completion of the following steps:
  • Connect the application
  • Enable OAuth authentication
  • Reset the user token
  • Configure the Salesforce connection
To connect to the Salesforce application do the following:
Step 1 – Log into Salesforce using an admin account.
salesforce-advancesetup
Step 2 – Go to Advanced Setup.
salesforce-newconnectedapp
Step 3 – Go to App Manager and create a Connected App.
salesforce-enableoauth
Step 4 – Fill in the details of the application: Application Name, API Name, Contact Email, select Enable OAuth Settings, and complete the mandatory information as callback URL and OAuth Scopes.
Step 5 – Save the Application.
salesforce-manageconnectedapps
Step 6 – Go to Manage Connected Apps and click the newly created application.
salesforce-manageconsumerdetails
Step 7 – Click Manage Consumer Details.
salesforce-consumerkey
Step 8 – Copy the Consumer Key and Consumer Secret in your Keypass.
To enable the OAuth authentication do the following:
oauthauthentication
Step 3 – Go to OAuth and OpenID Connect Settings in the Identity dropdown menu, enable the option to Allow OAuth Username-Password Flows.
To reset the user token do the following:
salesforce-usertoken-settings
Step 2 – Click Settings under the profile details.
salesforce-resetseuritytoken
Step 3 – Click Reset My Security Token.
salesforce-checkemail
Step 4 – An email containing the new token will be sent.
To configure the Salesforce connection do the following:
Step 1 – Log into Identity Manager using an admin account.
salesforce-connector
Step 2 – create a new Salesforce connector.
salesforce-connection
Step 3 – Add a new Salesforce connection.
salesforce-agent-settings
Step 4 – Fill the fields in the Connection Settings and choose the Filter.
The configuration of the Salesforce connector is completed.
Configuration​
This process is configured through a connection in the UI and/or the XML configuration, and in the appsettings.agent.json > Connections section. See the Connection topic for additional information.
*appsettings.agent.json*
"Connections": {
"<ConnectionIdentifier>": {
tip
Remember, the identifier of the connection and thus the name of the subsection must:
  • Be unique
  • Not begin with a digit
  • Not contain <, >, :, /, \, |, ?, *, and _.
The following example gets information via SCIM on a web application whose URL base is https://example.for.doc.com:
"Connections": {
"SCIMExport": {
"ApplicationId": "<applicationIdExample>",
"Server": "<https://example.for.doc.com/services/scim>",
"ApplicationKey": "<KEY>",
"Login": "<login>",
"Password": "<password>",
"Filter": "<Users|?filter=active eq \"true\">"
This example uses an account's credentials (login and password) with the application's credentials (ApplicationId and ApplicationKey).
The filter ?filter=active eq \"true\" retrieves active Users from the external system.
Setting attributes​
NameTypeDescription
Filter optionalStringFilters applied in the SCIM request retrieving the entities. You should write the filters as you would write them in the URL (including the "?"). For more details on the syntax, see the RFC document. Syntax:EntityNameInSCIM1|scimFilter1*EntityNameInSCIM2|scimFilter2*EntityNameInSCIM3|scimFilter3
OAuth2Url optionalStringURL which get tokens for the requests. The system can usually find this information, but sometimes the system gets it wrong, like Salesforce for example.
PageSize default value: 200StringMaximum number of elements returned by one request.
Server requiredStringURL of the SCIM endpoints of your application, excluding /v2.
ApplicationId optionalStringLogin of the application or of the application's Id provider.
Login optionalStringLogin of the account.
OAuthToken optionalStringGenerated OAuth token to connect to the application.
Password optionalStringPassword of the account.
ScimSyntax default value: RFCStringType of SCIM implementation: RFC - used for the systems that follow SCIM's rules; Salesforce - required when this connector targets Salesforce; cyberark - required when this connector targets cyberark.
The credential attributes (ApplicationId, ApplicationKey, Login, and Password) are used to obtain a token from the application for the connector's requests.
Output details​
This connector is meant to generate to the ExportOutput folder the following CSV files:
  • One file for each SCIM entity, coming from entity type mappings's connection tables, named <connectionIdentifier>_<entity>.csv, with one column for each property having a ConnectionColumn and each property without it but used in an entity association;
  • One file for each membership, coming from entity association mappings's connection tables, named <connectionIdentifier>_members_<entity>.csv, with the following columns:
    • Value — ID of the group
    • MemberId — ID of the group member
  • One file for each entity named Containers such as cyberark's privileged data, named <connectionIdentifier>_privilegedData_Containers.csv.
See the Application Settings and Entity Type Mapping topics for additional information.
For the connector to work properly, the connection tables must follow the naming conventions too: <identifier>_<entity> for entities and <identifier>_members_<entity> for links.
If the connection column describes a sub-property, then the name should have the following pattern: {property}:{sub-property}. The character ":" shouldn't be used in other situations.
For example, to retrieve information about Users, Groups, and Groups' members, use the following configuration:
<EntityTypeMapping Identifier="Salesforce_User" Connector="Salesforce" <b>ConnectionTable="SCIMExport_Users"</b>> <Property Identifier="SF_id" <b>ConnectionColumn="id"</b> IsPrimaryKey="true" /> <Property Identifier="givenName" <b>ConnectionColumn="name:givenName"</b> /> <Property Identifier="emails" <b>ConnectionColumn="emails:value"</b> /></EntityTypeMapping><EntityTypeMapping Identifier="Salesforce_Group" Connector="Salesforce" <b>ConnectionTable="SCIMExport_Groups"</b>> <Property Identifier="SF_id" <b>ConnectionColumn="id"</b> IsPrimaryKey="true" /> <Property Identifier="display" <b>ConnectionColumn="displayName"</b> /></EntityTypeMapping><EntityAssociationMapping Identifier="Salesforce_Group_Members" <b>Column1="value"</b> EntityPropertyMapping1="Salesforce_Group:SF_id" <b>Column2="MemberId"</b> EntityPropertyMapping2="Salesforce_User:SF_id" Connector="Salesforce" <b>ConnectionTable="SCIMExport_members_Groups"</b> />
This configuration creates SCIMExport_Users.csv with the column headers id, name:givenName, and emails:value; SCIMExport_Groups.csv with the column headers id and displayName; and SCIMExport_members_Groups.csv with the column headers value and MemberId.
Each column contains the value of the corresponding attribute. SCIM attributes are described in the RFC document.
Limitations​
The incremental mode only works for User entities and not for the others like Groups or Roles. It means that entities like Groups or Roles are always handled with the complete mode.
Fulfill​
This connector writes to the managed web application to create, update, and/or delete users with their attributes and group memberships, but no group or other entities.
Configuration​
The following example writes information to SCIM on a web application whose URL base is https://example.for.doc.com.
"Connections": {
"SCIMFulfillment": {
"Login": "<login>",
"ServiceSupportBulk": true,
"BulkMaxOperation": 10
This configuration specifies that bulk requests are supported with a maximum of 10 operations per request.
Setting attributes​
NameTypeDescription
BulkMaxOperation optionalInt32Maximum number of operations which can be sent in one bulk request.
ServiceSupportBulk optionalBooleanTrue to allow bulk requests. depends on the web application's SCIM implementation. See the RFC document for additional information.
ApplicationKey optionalStringPassword of the application or of the application's Id provider.
Password reset​
This connector doesn't reset passwords.
Credential protection​
  • RSA encryption, configured in the appsettings.encrypted.agent.json file
  • An Azure Key Vault safe
AttributeNaming Convention for the Key in Azure Key Vault
ApplicationIdConnections--<identifier>--ApplicationId
ApplicationKeyConnections--<identifier>--ApplicationKey
BulkMaxOperationConnections--<identifier>--BulkMaxOperation
LoginConnections--<identifier>--Login
PasswordConnections--<identifier>--Password
ServiceSupportBulkConnections--<identifier>--ServiceSupportBulk
ServerConnections--<identifier>--Server
  • A cyberark Vault able to store Active Directory's Login, Password, and Server.
See the RSA Encryption, Azure Key Vault, and cyberark's AAM Credential Providers topics for additional information.
Protected attributes are stored inside a safe in cyberark, into an account whose identifier can be retrieved by Identity Manager from *appsettings.<b>cyberark</b>.agent.json*.
For example:
"Connections": {
"SAPExportFulfillment": {
"Login": "SAPExportFulfillment_<b>cyberark</b>Key",
"Password": "SAPExportFulfillment_<b>cyberark</b>Key",
"Server": "SAPExportFulfillment_<b>cyberark</b>Key"
