SAP ERP 6.0 and SAP S4/HANA
This connector exports and fulfills users and roles from/to an SAP ERP 6.0 or SAP HANA instance.
This page is about ERP/SAP ERP 6.0.
Package: ERP/SAP ERP 6.0
Overview​
The SAP Enterprise Resource Planning (SAP ERP) software incorporates the core business processes of an organization, such as finance, production, supply chain services, procurements, human resources (HR), etc. The SAP ERP connector exports and fulfills data from/to an SAP ERP 6.0 system.
Prerequisites​
  • Reading first the appsettings documentation; See the appsettings.agent topic for additional information.
  • An ASE or HANA database with a service account, as a database administrator
  • A service account, as a SAP user with at least the roles for user management
  • The prerequisites for reading should be set up
  • The prerequisites for writing should be set up
To connect to the SAP database using SSH, use the following commands:
su sybaba
isql -S <database (ABA is the default value)> -U<administrator's login> -P<administrator's password> -X
For example:
isql -S ABA -Usapsso -PV1H#M$4JIgU$qd -X
Service account, as a SAP user with at least the roles for user management
Create a login for Identity Manager's service account with at least reading access on user management tables by using a command from the table below:
TableUsage
USR02Users table
AGR_USERSLinks between Users and Roles
AGR_TEXTSRoles labels according to the language
USER_ADDR
AGR_1016 AGR_PROFLinks between Profiles and Roles
USR10Profiles tables
USR11Profiles labels
AGR_DEFINERoles table
AGR_AGRSComposition links
USGRPGroups table
USGRPTGroups labels
UST04Links between Users and Profiles
UST10CLinks between Profiles and Sub-profiles
AGR_TCODESLinks between Roles and Transactions
T002Languages codes
For example:
execute sp_addlogin <login>, <password>, <database (ABA is the default value)>
go
use ABA
go
execute sp_adduser <login>
go
grant select on ABA.SAPSR3.USR02 to usercube
grant select on ABA.SAPSR3.AGR_USERS to usercube
grant select on ABA.SAPSR3.USER_ADDR to usercube
grant select on ABA.SAPSR3.AGR_1016 to usercube
grant select on ABA.SAPSR3.USR10 to usercube
grant select on ABA.SAPSR3.USR11 to usercube
grant select on ABA.SAPSR3.AGR_AGRS to usercube
grant select on ABA.SAPSR3.USGRP to usercube
grant select on ABA.SAPSR3.UST04 to usercube
grant select on ABA.SAPSR3.AGR_TCODES to user
grant select on ABA.SAPSR3.T002 to usercube
Go
Set up the prerequisites for reading
To set up the prerequisites for reading follow the steps below.
Step 1 – Copy the DLL Sap.Data.Hana.Core.v2.1.dll into the Runtime of Identity Manager.
connectorreadprerequisites1
Step 2 – Unzip the "hdbclient.zip" archive to C: drive and add the path to the Path environment variables.
connectorreadprerequisites2
Step 3 – Create environment variables: HDBADOTNET=C:\hdbclient\ado.net and HDBADOTNETCORE=C:\hdbclient\dotnetcore.
Set up the prerequisites for writing
Ensure the Read prerequisites are configured first.
Step 1 – Copy the provided DLL sapnwrfc.dl into the Runtime of Identity Manager.
Step 2 – Unzip the dotnet86.zip archive to C:\dotnetx86.
Step 3 – Copy the DLLs icudt50.dll, icuin50.dll and icuuc50.dll into the Runtime of Identity Manager.
connectorwriteprerequisites
Step 4 – Disable DLLs search by adding the environment variable NLSUI_7BIT_FALLBACK=YES.
connectorwriteprerequisites2
Step 5 – Add new environment variable USERCUBE_DOTNET32 containing the path to dotnetx86 (e.g.: C: \donetx86\dotnet.exe).
Export​
This connector extracts users, roles, profiles, profile memberships, role memberships and groups from an SAP ERP instance, and writes the output to CSV files.
Configuration​
This process is configured through a connection in the UI and/or the XML configuration, and in the appsettings.agent.json > Connections section. See the Connection topic for additional information.
*appsettings.agent.json*
  "Connections": {
    "<ConnectionIdentifier>": {
tip
Remember, the identifier of the connection and thus the name of the subsection must:
  • Be unique
  • Not begin with a digit.
  • Not contain <, >, :, /, \, |, ?, *, and _.
For example:
    "Connections": {
        "SAPExportFulfillment": {
            "Server": "serverUrl",
            "AseLogin": "login",
            "AsePassword": "password",
            "Instance": "sapInstance",
            "Port": "4242",
            "Client": "123",
            "Language": "fr"
NameTypeDescription
IsHana default value: falseBooleanTrue to connect to an S/4 HANA instance instead of an ERP 6.0.
AseLogin requiredStringlog in to connect to SAP ASE.
AsePassword requiredStringPassword to connect to SAP ASE.
Client requiredStringClient id of SAP.
Instance requiredStringInstance of the SAP database.
Language requiredStringSAP language.
Port requiredStringPort of the SAP ERP server.
Server requiredStringURL of the SAP ERP server.
Output details​
This connector is meant to generate to the ExportOutput folder the following files:
  • SAPExportFulfillment_users.csv;
  • SAPExportFulfillment_roles.csv;
  • SAPExportFulfillment_usersroles.csv;
  • SAPExportFulfillment_profiles.csv;
  • SAPExportFulfillment_profilesprofiles.csv;
  • SAPExportFulfillment_rolesprofiles.csv;
  • SAPExportFulfillment_usersprofiles.csv;
  • SAPExportFulfillment_rolesroles.csv;
  • SAPExportFulfillment_groups.csv;
  • SAPExportFulfillment_rolestransactions.csv.
See the Application Settings topic for additional information.
Fulfill​
This connector can provision users, role memberships and group memberships to SAP ERP.
Configuration​
Same as for export, fulfill is configured through connections. See the SAP ERP 6.0 and SAP S4/HANA topic for additional information.
For example:
    "Connections": {
            "Server": "<serverUrl>",
            "BapiLogin": "<login>",
            "BapiPassword": "<password>"
Setting attributes​
NameTypeDescription
BapiLogin requiredStringlog in to connect to the specified server.
BapiPassword requiredStringPassword to connect to the specified server.
Password reset​
See the appsettings.agent topic for additional information on how to configure password reset settings.
When setting a password for an SAP ERP user, the password attribute is defined by the password specified in the corresponding RessourceTypeMapping. See the Sap Resource Type Mapping topic for additional information.
Credential protection​
  • RSA encryption, configured in the appsettings.encrypted.agent.json file
  • An Azure Key Vault safe
AttributeNaming Convention for the Key in Azure Key Vault
ServerConnections--<identifier>--Server
AseLoginConnections--<identifier>--AseLogin
AsePasswordConnections--<identifier>--AsePassword
InstanceConnections--<identifier>--Instance
PortConnections--<identifier>--Port
ClientConnections--<identifier>--Client
LanguageConnections--<identifier>--Language
BapiLoginConnections--<identifier>--BapiLogin
BapiPasswordConnections--<identifier>--BapiPassword
SystemNumberConnections--<identifier>--SystemNumber
  • A cyberark Vault able to store Active Directory's Login, Password, and Server.
See the RSA Encryption, Azure Key Vault, and cyberark's AAM Credential Providers topics for additional information.
Protected attributes are stored inside a safe in cyberark, into an account whose identifier can be retrieved by Identity Manager from *appsettings.<b>cyberark</b>.agent.json*.
For example:
  "Connections": {
        "Login": "SAPExportFulfillment_<b>cyberark</b>Key",
        "Password": "SAPExportFulfillment_<b>cyberark</b>Key",
        "Server": "SAPExportFulfillment_<b>cyberark</b>Key"
