Active Directory
This connector exports and fulfills users and groups from/to an Active Directory instance.
This page is about Directory/Active Directory. See the Active Directory topic for additional information.
Package: Directory/Active Directory
Overview​
Active Directory is a directory service developed by Microsoft for Windows domain networks. The Active Directory connector exports Active Directory (AD) entries to Identity Manager's resource repository. This connector also enables automated provisioning from the resource repository to the AD.
Prerequisites​
  • Reading first the appsettings documentation; See the appsettings.agent topic for additional information.
  • Opening the LDAP feed from Identity Manager's server to the Active Directory, with the ports 389 for LDAP and 636 for LDAPS.
  • A service account with reading and writing permissions on the target Active Directory instance. It means that the Replicating Directory Changes rights are required for the service account, but also for the Active Directory root and the AD children. See the instructions below for additional information.
  • An SSL connection which is mandatory for the AD connector to initialize and change a password.
  • Enabling rights inheritance in the Advanced Security Settings.
Enable Active Directory Permissions​
To enable permissions, the Active Directory administrator must do the following:
Step 1 – Check the View details in the Active Directory and Computers.
Enable Permissions - Step 1
Step 2 – Open the Advanced Security Settings dialog box for the domain root.
Enable Permissions - Step 2
Step 3 – Select the Replicating Directory Changes checkbox from the list.
Enable Permissions - Step 3
Step 4 – To change groups' membership, in the Applies field, select Descendent Group object and select the Read Members and Write Members check boxes from the list.
Read/Write Members
Step 5 – To Reset Password capabilities, in the Applies field, select Descendent User object and select the Read lockoutTime and Write lockoutTime check boxes from the list.
Read/Write Lockout Times
Administrator rights must not be granted to the service account. Doing otherwise would create a security breach. Administrator rights must only be granted to the target perimeter.
Export​
For a configured set of Active Directory entries, this connector exports all attributes from the connector's configuration to CSV files.
The export is executed by a job from the UI, or via Usercube-Export-ActiveDirectory.exe in the command prompt.
Configuration​
This process is configured through a connection in the UI and/or the XML configuration, and in the appsettings.agent.json > Connections section:
*appsettings.agent.json*
                "Connections": {
                "<ConnectionIdentifier>": {
  • Be unique.
  • not begin with a digit.
The following example configures a connection to the Active Directory Domain Controller contoso.server.com using Basic Authentication with BaseDN, Login, Password with EnableSSL for all entries ( "Filter": "(objectclass=*)"):
                    "Connections": {
                    "ADExport": {
                    "Filter": "(objectclass=*)",
                    "Servers": [>                     {
                    "Server": "contoso.server.com",
                    "BaseDN": "DC=contoso,DC=com"
                    "AuthType": "Basic",
                    "AsAdLds": false,
                    "EnableSSL": true,
                    "Login": "Contoso",
                    "NoSigning": false,
                    "Password": "ContOso$123456789",
                    "RetryDelay": 10
Setting attributes​
NameTypeDescription
Servers requiredServer ListList of pairs that define the target servers, made of: - Server: domain controller URL. - BaseDN: base Distinguished Name used to connect to the related server.
AsAdLds optionalBooleanTrue to state the managed system as an AD LDS. It is used for extracting the schema through the connection screen.
EnableSSL optionalBooleanTrue to enable SSL protocol for authentication requests. Recommended when using AuthType set to Basic because basic authentication packets aren't encrypted by default. SSL isn't available on Linux.
NoSigning optionalBooleanTrue to disable Kerberos encryption.
AuthType default value: NegotiateStringAuthentication method used by Identity Manager to authenticate to the server. Access is granted to the target domain controller: Anonymous - without any login/password; Basic - via the BaseDN, Login, and Password attributes; Negotiate - via GSS-API negotiations with the Kerberos mechanism used for authentication.
Login optionalStringLogin used by Identity Manager for basic authentication. It is required when AuthType is set to Basic.
Password optionalStringPassword used by Identity Manager for basic authentication. It is required when AuthType is set to Basic.
Filter requiredStringValue that filters out the corresponding entries from the AD instance which will not be exported. only non-filtered entries are exported. The filter value complies with Microsoft's search filter syntax.
RetryDelay optionalInt32Time (in milliseconds) after which Identity Manager retries a timeout request.
RequestTimeout optionalInt32Time (in seconds) after which a connection faces a timeout.
ConnectionTimeout optionalInt32Time (in seconds) after which a connection faces a timeout.
Output details​
This connector is meant to generate:
  • A file named <connectionIdentifier>_entries.csv, with one column for each property having a ConnectionColumn and each property without it but used in an entity association;
Any property can be exported in a specific format when specified. See the References: Format for the EntityPropertyMapping topic for additional information.
  • An additional file for each related table other than entries;
  • A cookie file named <connectionIdentifier>_cookie.bin, containing the time of the last export to perform incremental exports.
Most exports can be run in complete mode, where the CSV files will contain all entries, or in incremental mode, where CSV files will contain only the entries which have been modified since the last synchronization.
A task can use the IgnoreCookieFile boolean property, and a command line (with an executable) can use the option --ignore-cookies.
The CSV files are stored in the ExportOutput folder, and the cookie file in the ExportCookies folder. See the Application Settings topic for additional information.
For example, with the following configuration example:
                <EntityType Identifier="AD_Entry" DisplayName_L1="AD - Entry" >  <Property Identifier="dn" DisplayName_L1="dn" IsKey="true" TargetColumnIndex="0" Type="String" />  <Property Identifier="objectCategory" DisplayName_L1="objectCategory" TargetColumnIndex="4" Type="String" />  <Property Identifier="objectGuid" DisplayName_L1="objectGuid" TargetColumnIndex="3" Type="String" IsKey="true" />  <Property Identifier="objectSid" DisplayName_L1="objectSid" TargetColumnIndex="9" Type="String" />  <Property Identifier="pwdLastSet" DisplayName_L1="pwdLastSet" TargetColumnIndex="13" Type="String" />  <Property Identifier="thumbnailPhoto" DisplayName_L1="thumbnailPhoto" Type="Binary" />  <Property Identifier="ParentDn" DisplayName_L1="ParentDN" Type="ForeignKey" TargetColumnIndex="128" />  <Property Identifier="children" DisplayName_L1="children" Type="ForeignKey" />  <Property Identifier="Member" DisplayName_L1="Member" Type="ForeignKey" />  <Property Identifier="memberOf" DisplayName_L1="memberOf" Type="ForeignKey"/></EntityType><EntityTypeMapping Identifier="AD_Entry" Connector="AD" ConnectionTable="ADExport_entries">  <Property Identifier="dn" <b>ConnectionColumn="dn"</b> IsUniqueKey="true" />  <Property Identifier="objectCategory" <b>ConnectionColumn="objectCategory"</b> Format="rdn" />  <Property Identifier="objectGuid" <b>ConnectionColumn="objectGuid"</b> IsPrimaryKey="true" Format="guid" />  <Property Identifier="objectSid" <b>ConnectionColumn="objectSid"</b> IsUniqueKey="true" Format="sid"/>  <Property Identifier="pwdLastSet" <b>ConnectionColumn="pwdLastSet"</b> Format="1601date" />  <Property Identifier="thumbnailPhoto" <b>ConnectionColumn="thumbnailPhoto"</b> Format="binary" /></EntityTypeMapping><EntityAssociation Identifier="AD_Entry_parentdn" DisplayName_L1="Parent DN" IsProperty1Collection="true" Property2="AD_Entry:ParentDn" Property1="AD_Entry:children" /><EntityAssociation Identifier="AD_Entry_member" DisplayName_L1="Member" IsProperty1Collection="true" IsProperty2Collection="true" Property1="AD_Entry:Member" Property2="AD_Entry:memberOf" /><EntityAssociationMapping Identifier="AD_Entry_parentdn" Column2="dn" <b>Column1="parentdn"</b> ConnectionTable="ADExport_entries" EntityPropertyMapping1="AD_Entry:dn" EntityPropertyMapping2="AD_Entry:dn" Connector="AD" /><EntityAssociationMapping Identifier="AD_Entry_member" Column1="dn" <b>Column2="member"</b> ConnectionTable="ADExport_members" EntityPropertyMapping1="AD_Entry:dn" EntityPropertyMapping2="AD_Entry:dn" Connector="AD" />
The result is C:/identitymanagerContoso/Temp/ExportOutput/*ADExport_entries.csv* with a column for each scalar property. See the Entity Model topic for additional information.
                command,dn,objectCategory,objectGuid,objectSid,pwdLastSet,thumbnailPhoto,parentdn
Also, ADExport_member as ConnectionTable in a mapping will trigger the generation of the file C:/identitymanagerContoso/Temp/ExportOutput/*ADExport_member.csv* with member as link attribute:
                command,dn,member
And C:/identitymanagerContoso/Work/ExportCookies/ADExport_cookie.bin
Synchronize multiple forests​
This connector can export resources from multiple forests trusted by the same AD domain.
It requires specifying the Server and BaseDN pairs in Servers for all the forests used as source for the export.
Each BaseDN will generate a cookie file, but the entries from all BaseDN properties will be written to the same CSV file.
The following example exports data from two sources: both on the same Server (contoso.server.com), but on two different BaseDNs (DC=contoso,DC=com and DC=defense,DC=contoso,DC=com).
                    "Connections": {
                    "ADExport": {
                    "Servers": [>                     {
                    "Server": "<contoso.server.com>",
                    "BaseDN": "<DC=contoso,DC=com>"
                    "BaseDN": "<DC=defense,DC=contoso,DC=com>"
                    "AuthType": "<Basic>",
                    "Login": "<Contoso>",
                    "Password": "<YourPasswordHere>",
                    "Filter": "<(objectclass=*)>",
                    "EnableSSL": "<true>"
The export creates two cookie files: ADExport_cookie_0.bin for the first BaseDN, and ADExport_cookie_1.bin for the second BaseDN, but the entries of both BaseDN properties will be written in ADExport_entries.csv.
Fulfill​
This connector writes to the Active Directory to create, update, and delete entries, initiated manually through the UI or automatically by enforcing the policy. See the Evaluate Policy topic for additional information.
Configuration​
The following example connects to an AD LDS system located at contoso.server.com.
                    "Connections": {
                    "ADFulfillment": {
                    "Servers": [>                     {
                    "AsAdLds": "true",
                    "EnableSSL": true,
                    "NoSigning": false,
Setting attributes​
NameTypeDescriptionDetails
AsAdLds optionalBooleanTrue to state the managed system as an AD LDS. It isInfo: used for extracting the schema through the connection screen.
Login optionalStringLogin used by Identity Manager for basic authentication. NOTE: It is required when AuthType is set to Basic.
Password optionalStringPassword used by Identity Manager for basic authentication. NOTE: It is required when AuthType is set to Basic.
Output details​
This connector can create a new resource, and update and delete an existing resource via the UI.
A new resource is created with the state disabled, corresponding to the useraccountcontrol value 514. When it is approved, its disabled state is removed and the useraccountcontrol value becomes 512.
Provision multiple forests​
Same as for export, this connector can fulfill resources to multiple forests trusted by the same AD domain, by specifying the Server and BaseDN pairs in Servers for all forests.
The following example fulfills data to two targets: both on the same Server (contoso.server.com), but on two different BaseDNs (DC=contoso,DC=com and DC=defense,DC=contoso,DC=com).
                "Connections": {
                "ADFulfillment": {
                "Servers": [{
                "AsAdLds": "true"
Add attributes to the requests​
Some systems using the LDAP protocol require additional attributes in the creation and/or update requests.
If these attributes aren't synchronized in Identity Manager, then they can't be computed and provided by scalar rules or navigation rules. In this case, they can be given as arguments in the provisioning order, through the ResourceType's ArgumentsExpression.
The following example adds the attribute description with a value depending on what is modified:
                <ResourceType Identifier="LDAP_Entry_NominativeUser" DisplayName_L1="LDAP User (nominative)" Policy="Default" TargetEntityType="LDAP_Entry" Category="Accounts" SourceEntityType="Directory_User" ApprovalWorkflowType="One" HideOnSimplifiedView="true"
                ArgumentsExpression="C#:resource:
                var arguments = new System.Collections.Generic.Dictionary<string, string>();
                if (provisioningOrder.HasChanged("cn")) {
                arguments.Add("description", "This entry's login has been modified by Usercube.");
                else if (provisioningOrder.HasChanged("mail")) {
                arguments.Add("description", "This entry's email has been modified by Usercube.");
                else {
                arguments.Add("description", "This entry has been modified by Usercube.");
                return arguments;">
                <ScalarRule Property="givenName" Binding="FirstName" />    <ScalarRule Property="cn" Binding="Login" />    <ScalarRule Property="sn" Binding="LastName" />    <ScalarRule Property="employeeNumber" Binding="EmployeeId" /></ResourceType>
Password reset​
See the appsettings.agent topic for additional information on how to configure password reset settings.
Credential protection​
  • RSA encryption, configured in the appsettings.encrypted.agent.json file. See the RSA Encryption topic for additional information.
  • An Azure Key Vault safe; See the Azure Key Vault topic for additional information.
  • A CyberArk Vault able to store Active Directory's Login, Password, and Server. See the CyberArk's AAM Credential Providers topic for additional information.
