Write a Template for a Ticket Connector
This guide shows how to write a template that will be used by a Ticket connector to complete the title and the description of the ticket. The information which will be written in the ticket will come from the generated provisioning order and from literal strings written in the template.
Attributes​
NameDetails
UsernameType String Description Is the name of the user for which the ticket is created.
ResourceTypeType String Description Is the identifier or the resource type.
UsercubeProfileLinkType String Description Is the link allowing to access the user profile.
AddedLinkedEntitiesType List Description Is the list of links to add in the system.
RemovedLinkedEntitiesType List Description Is the list of links to remove in the system.
DisplayAddType Boolean Description True if there are any links to add.
DisplayRemoveType Boolean Description True if there are any links to remove.
EntityType Dictionary Description Is the list of values to assign to the resource.
ProvisioningOrder.ChangeTypeType String Description Corresponds to the action of the provisioning order (Added, Deleted, Modified).
ProvisioningOrder.ChangesType Dictionary Description Is the list of changes.
ProvisioningOrder.ResourceType Dictionary Description Is the current state of the resource.
ProvisioningOrder.OwnerType Dictionary Description Is the owner of the resource.
Operations​
The template uses the Mustache syntax. Several operations are already provided, but you can find more on this page.
Identity Manager also provides a way of using conditions with Mustache for the following operations:
  • >: superior to
  • <: inferior to
  • ==: equal to
  • !=: different from
Example​
{{#each ProvisioningOrder.Changes}}
{{#ifCond this '==' 'INTERNAL'}}
This account is for an internal employee.
{{else}}
This account is for an external employee.
{{/ifCond}}
{{/each}}
This template goes through all the changes provided by the provisioning order. If any one of them meets the condition for an internal employee, the internal employee message is displayed. Several messages can be shown if several changes meet the condition.
Template example​
Please create a resource "{{ResourceType}}" for user {{Username}}.
**For more information on the user, see: {{UsercubeProfileLink}}**
{{#ifCond ProvisioningOrder.ChangeType '==' 'Deleted'}}
To delete the account, please contact the IT team.
{{/ifCond}}
This is a change: {{this}}
{{/each}}
The resource must have the following values:
{{#Entity.GetEnumerator}}
- {{Key}}: {{Value}}
{{/Entity.GetEnumerator}}
{{#DisplayAdd}}
Add the following links:
{{/DisplayAdd}}
{{#AddedLinkedEntities}}
- {{Name}}
{{#Values.GetEnumerator}}
- {{Value}}: {{Key}}
{{/Values.GetEnumerator}}
{{/AddedLinkedEntities}}
