Write a Robot Framework Script
This guide shows how to write a Robot Framework script that will be used by Robot Framework.
Structure of a Robot Framework Script​
Build the skeleton​
A Robot Framework script is divided into four main parts:
  1. Settings: contains the instructions to import library or external resource files.
  2. Variables: contains the global variables shared by all the functions in the script.
  3. Keywords: contains all the functions defined by the user.
  4. Test Cases: contains the functions which will be run when the script is launched.
Example​
*** Settings ***
Library Telnet
*** Variables ***
${IPADDRESS} 192.168.1.22
*** Keywords ***
Open Telnet Connection
Open Connection ${IPADDRESS} prompt=$
*** Test Cases ***
Run Provisioning
Let's analyze the four parts of this example:
  • Settings: This section imports the Telnet library to use the functions defined in it.
  • Variables: This section defines the variable IPADDRESS to use it later.
  • Keywords: This section defines a custom function called Open Telnet Connection. It will use a function defined in the Telnet library (called Open Connection) and the variable IPADDRESS which has been defined before in the Variables section.
  • Test Cases: This section defines the main function which you can call Run Provisioning (it can be named anything), and which will be run when launching the script. It will use the function Open Telnet Connection.
Robot Framework needs two spaces between two different instructions to parse them correctly. For example, Open Connection consists of only one instruction. Only one space is thus needed between the two words. But, Open Connection ${IPADDRESS} consists of two instructions, the function and the parameter. Two spaces are then required to separate Connection from ${IPADDRESS}. To read your script more easily, you could also use the pipe character (|) between instructions, like this: Open Connection | ${IPADDRESS}.
See the Robot Framework Libraries for additional information.
Define specific functions​
To use a Robot Framework script for provisioning external systems with Identity Manager, the following elements are required in the script:
  • The import of a resource file written by Identity Manager called UsercubeRobotFramework.resource.
  • The definition of three functions which will be called by Identity Manager to perform three required actions: ExecuteAdd, ExecuteDelete and ExecuteModify. These functions are where you will write the actions to perform on the external system.
  • The use of one function to start the provisioning called Launch Provisioning.
Never modify the resource file UsercubeRobotFramework.resource.
Example​
The resource file defined at the beginning of the script is located in Identity Manager's Runtime folder. Therefore, you will have to change the path accordingly.
*** Settings ***
Resource C:/identitymanagerContoso/Runtime/identitymanagerRobotFramework.resource
*** Keywords ***
ExecuteAdd
[Arguments] ${order}
ExecuteDelete
ExecuteModify
*** Test Cases ***
Run Provisioning
Launch Provisioning
The parameter ${order} is mandatory only for the three functions: ExecuteAdd, ExecuteDelete and ExecuteModify. It is an object corresponding to the following sample provisioning order (JSON):
"ChangeType": "Added",
"WorkflowInstanceId": "81",
"Owner": {
"Id": "21511",
"Identifier": "007",
"EmployeeId": "007",
"PhotoTag": -3065,
"MainFirstName": "James",
"MainLastName": "Bond",
"ResourceType": {
"Id": "-41",
"SourceEntityType": {
"Id": "51",
"TargetEntityType": {
"Id": "70",
"Identifier": "RobotFramework_User"
"Identifier": "RobotFramework_User_NominativeUser"
"Changes": {
"identifier": "007",
"firstName": "James",
"lastName": "Bond"
The elements of ${order}can be accessed like this: ${order['Changes']['identifier']}.
See the Robot Framework User Guide for additional information.
Keywords​
KeywordDetails
Catch KeywordArguments Keyword: Keyword *args Description Launches Keyword with the given arguments *args if the keyword launched by Try Keyword failed. If Try Keyword wasn't called, this keyword will not do anything. Catch Keyword should always be called right after Try Keyword. Example Try to connect to Usercube.com. If the connection fails, restart the browser and try to connect to Usercube.com: Connect to URL Try Keyword Go To Usercube.com Catch Keyword Restart Browser At URL Usercube.com
Generate PasswordDescription Generates a password based on the Password Reset Settings associated to the Resource Type Mappings being provisioned. Send Password Notification should always be called after Generate Password, preferably right after the password is used. If Send Password Notification isn't called before the provisioning of the resource is over, it will automatically be called. If multiple passwords should be generated, Send Password Notification should be called after each password generation. Returns Password: string
Get Secure DataArguments Attribute: string Erase Data: boolean Description Retrieves the secured option Attribute from the connector configuration. If Erase Data is set to true, the secured option is deleted after it is read. Example Get Login option and erase it: ```Get Secure Data
Launch ProvisioningDescription Launches the provisioning defined by the provisioning orders. This keyword is required for any provisioning to happen.
Log DebugArguments Message: string Description Logs Message at the Debug log level. Example Log a keyword failure message: Log Debug The keyword has failed
Log ErrorArguments Message: string Description Logs Message at the Error log level. Example Log a keyword failure message: Log Error The keyword has failed
Send Password NotificationDescription Sends a notification containing the last password generated. If Generate Password is called and Send Password Notification isn't called before the provisioning of the resource is over, Send Password Notification will automatically be called.
Try KeywordArguments Keyword: Keyword *args Description Launches Keyword with the given arguments *args, and ignores its errors. If Keyword fails, the keyword sent to Catch Keyword will run. Try Keyword should always be called right before Catch Keyword. Example Try to connect to Usercube.com. If the connection fails, restart the browser and try to connect to Usercube.com: Connect to URL Try Keyword Go To Usercube.com Catch Keyword Restart Browser At URL Usercube.com
Error handling​
Consider a web application that contains user information. Suppose a user is missing from the web application. When the script attempts to reach the user's information page, it will reach an error page, and fail. The next user's provisioning starts, but the web browser is still on the error page, so the script keeps failing.
In this example, if a user's provisioning fails, each subsequent provisioning will fail. This failure issue can be solved with the error handling custom keywords.
Consider the following example using the Robot Framework Selenium library:
Open Identity Manager Website
Open Browser
Connect To Usercube
[Teardown] Close Browser
Restart Browser
[Arguments] ${url}
Log Debug An error has occured, restarting the browser
Close Browser
Open Browser ${url}
Connect To Usercube
Catch Keyword Restart Browser Usercube.com
Page Should Contain Usercube
In this example, the keyword Open Identity Manager Website opens a browser, then calls Connect To Usercube. To ensure that the browser is closed regardless of the script's success, the Close Browser keyword is used in a teardown. A keyword in a teardown is always executed regardless of what happens in the script or in the teardown.
The Restart Browser keyword logs a debug message before restarting the browser to help debug the script. The Connect To Usercube tries to use the Go To keyword to connect to the Usercube.com web page. As Go To is used with Try Keyword, if the execution fails, Restart Browser is called by Catch Keyword. This means that if the browser fails to load Usercube.com, the browser restarts. Last, Connect To Usercube verifies that the page contains the word Usercube.
Error Handling for ExecuteAdd, ExecuteDelete, and ExecuteModify​
The ExecuteAdd, ExecuteDelete, and ExecuteModify methods are harder to interact with. First, it isn't possible to get their execution status within the script. Second, if the execution failed, it should be kept as a failure to log the failure.
To simplify error handling, consider the following structure:
Execute Add
Try Keyword Add User ${order}
Catch Keyword Restart Program And Fail Add User failed.
Add User
Click New User
Fill In Information ${order}
Click Add User
[Arguments] ${failmessage}
Close Program
Start Program
Fail ${failmessage}
In this example, ExecuteAdd doesn't call the custom keywords to add a new user directly, and only calls Add User instead. This means you can call Add User from the Try Keyword keyword. If Add User fails, then Execute Add fails. Therefore you can catch a failure with this structure.
Restart Program And Fail fails. This failure is necessary as the provisioning order would be counted as a success otherwise.
Testing a RobotFramework script​
To write a RobotFramework script, you must test that it works. Test the script by running a fulfillment job from the Identity Manager interface. While this kind of test proves that everything works as expected, it can take a long time. There is a faster method to check that the script runs.
Suppose the RobotFramework script's path is RobotFramework/script.robot.
You need the following elements :
  • A provisioning order, in folder RobotFrameworkScript/Order. The provisioning order can be encrypted or unencrypted. The script will write the encrypted results to RobotFrameworkScript/Order/results.csv.
  • The path to the Runtime folder. For example, consider this path as C:/identitymanagerDemo/Runtime.
The RobotFramework/script.robot script may be run from the command prompt.
cd RobotFramework
robot --variable ORDERPATH:./Order --variable RUNTIMEPATH:C:/identitymanagerDemo/Runtime --variable RESULTPATH:./Order/results.csv ./script.robot
This command will generate an output file, a log file, and a report file in the RobotFramework folder. This command will also write information to the command prompt.
For most testing cases, only the command prompt information and the log file matter, written at RobotFramework/log.html. The other outputs can be removed.
cd RobotFramework
robot --loglevel NONE --report NONE --variable ORDERPATH:./Order --variable RUNTIMEPATH:C:/identitymanagerDemo/Runtime --variable RESULTPATH:./Order/results.csv ./script.robot
Get Secure Data and Generate Password​
Most keywords aren't different when a script is launched manually. The keywords Get Secure Data and Generate Password are exceptions.
  • Get Secure Data: This keyword expects the Robot Framework process to receive a json list of attributes in the stdin stream. This can be provided manually by writing the data in the command prompt. As an example, if the script requires a Login and Password attribute : {"Login":"login","Password":"password"}
  • Generate Password: This keyword expects a file that contains the Password Reset Settings associated to the provisioned Resource Type Mappings. The easiest way to enable the Generate Password keyword is as follow:
    • Launch the Robot Framework fulfillment through the Identity Manager web application with a blank script.
    • Copy the PasswordResetSettings folder generated in the most recent subfolder of Work/FulfillRobotFramework.
    • Paste the folder in the same folder as the provisioning order.
Use Case: Write a Script to Fulfill a CSV File​
The goal of the script is to append, for each provisioning order, a line in a CSV file located on an external system that is accessed through a Telnet connection.
Let's consider the following ResourceType:
<ResourceType Identifier="RobotFramework_User_NominativeUser" DisplayName_L1="Robot Framework User (nominative)" Policy="Default" TargetEntityType="RobotFramework_User" Category="RobotFramework" SourceEntityType="Directory_User" ApprovalWorkflowType="One"> <ScalarRule Property="identifier" Binding="EmployeeId"/> <ScalarRule Property="firstName" Binding="FirstName"/> <ScalarRule Property="lastName" Binding="LastName"/></ResourceType>...
Insert;007;James;Bond
Define settings​
In every Robot Framework script, import the resource file UsercubeRobotFramework.resource. In this example, also import the Telnet library to use its functions.
*** Settings ***
Library Telnet
Define variables​
To connect to the external system through Telnet, you need an IP address corresponding to the external system. Store the IP address in the global variable ${IPADDRESS}. Also use the global variable ${CSVFILEPATH} to define the CSV file where the data will be written in the external system.
*** Variables ***
${CSVFILEPATH} /home/contoso/robotframework_users.csv
Define custom keywords​
Define all the custom functions that are used to provision the external system:
  • Delete CSV File: removes a possible pre-existing CSV file.
  • Write In CSV: executes a command to write the line in the CSV file in the external system.
  • Write Data: formats the line to write in the CSV and calls Write In CSV to write it.
  • Write Header: defines the header to write in the CSV and calls Write Data to write it.
  • Open Telnet Connection: opens the Telnet connection to the external system using the login and the password defined in the Robot Framework attribute in appsettings.agent.json, as well as the IP address defined in the Variables section.
*** Keywords ***
Delete CSV File
Execute Command rm ${CSVFILEPATH}
Write In CSV
[Arguments] ${line}
Execute Command echo ${line} >> ${CSVFILEPATH}
Write Data
[Arguments] ${command} ${identifier} ${firstName} ${lastName}
Write In CSV '"${command}","${identifier}","${firstName}","${lastName}"'
Write Header
Write Data Command identifier firstName lastName
Read Until login
${LOGIN}= Get Secure Data Login False
Write ${LOGIN}
Read Until Password
${PASSWORD}= Get Secure Data Password True
Write ${PASSWORD}
The method Get Secure Data will retrieve the value of the attributes filled in the options in appsettings.agent.json. This is the method strongly recommended by Identity Manager. However, you could also enter the value directly into the script (example: ${LOGIN}= UserName). This may be easier for initial testing purposes.
Define mandatory keywords​
To be able to provision the external system, use the three required functions: ExecuteAdd, ExecuteDelete and ExecuteModify. These methods are called by the connector depending on the action to perform on the external system.
*** Keywords ***
ExecuteAdd
Write Data Insert ${order['Changes']['identifier']} ${order['Changes']['firstName']} ${order['Changes']['lastName']}
ExecuteDelete
Write Data Delete ${order['Changes']['identifier']} ${order['Changes']['firstName']} ${order['Changes']['lastName']}
ExecuteModify
Write Data Update ${order['Changes']['identifier']} ${order['Changes']['firstName']} ${order['Changes']['lastName']}
Here, for each action, use the function Write Data defined in the previous section to write the changes to the CSV file with a corresponding word Insert, Delete or Update.
Define test cases​
The function launched by the Robot Framework script will be written in the section Test Cases and will be called Run Provisioning.
*** Test Cases ***
Run Provisioning
Delete CSV File
Write Header
Launch Provisioning
Close All Connections
In this test case, the following operations are performed in Run Provisioning:
  • Open the Telnet connection with the external system.
  • Remove a possible pre-existing CSV file.
  • Write the header to the new CSV file.
  • Launch the Identity Manager provisioning. The method Launch Provisioning is mandatory when using the Robot Framework connector.
  • Close the Telnet connection with the external system.
Read the full script​
*** Settings ***
Library Telnet
*** Variables ***
*** Keywords ***
ExecuteAdd
ExecuteDelete
ExecuteModify
Delete CSV File
Write In CSV
[Arguments] ${line}
Write Data
Write Header
Read Until login
Write ${LOGIN}
Read Until Password
Write ${PASSWORD}
*** Test Cases ***
Run Provisioning
Delete CSV File
Write Header
Launch Provisioning
