Production-Ready Installation
This guide leads the reader through the steps to install Identity Manager for production purposes.
1.__Before proceeding__, you should go through the Overview and Requirements sections to make fundamental decisions about Identity Manager setup, including:
  • Whether to install the database within the Identity Manager Server or on a separated workstation.
  • How many Agents will be installed?
  • If only one Agent is installed, whether to install it as an integrated agent or a separate agent.
  • What end-user authentication methods are to be used?
  • What hosting environment is used for the Agent and the Server?
2. You should get the following archives ready:
  • Identity Manager runtime: runtime_<version>.zip
  • Identity Manager database scheme: Usercube.sql from the SQL_<version>.zip
3. This guide is based on the following choices:
  • Identity Manager Server running with IIS
  • Identity Manager Database connection with Windows authentication
With this guide, you can extrapolate less common configurations and find links to the relevant Network Configuration sections.
The examples use the fabled Contoso Corporation as target organization.
What's Next​
The first step consists in Create a Working Directory.
