Automate Role Assignments
How to manually build rules to automate the assignment of roles to identities. See the Create Roles in the Role Catalog topic for additional information.
Single role rules and composite role rules are assignment rules. Assignment rules are designed to automatically assign respectively single roles and composite roles (based on specific criteria) to identities. One rule must be created for every role to assign. See the Create Roles in the Role Catalog topic for additional information.
Input | Output |
Role Catalog (required) | Role assignment rules |
Create a Role Assignment Rule
Create a role assignment rule by proceeding as follows:
Access the rules page by clicking on Access Rules on the home page in the Configuration section.
In the dropdown menu at the top left, choose the source entity type for the future scalar rule.
Click on the Composite Roles or Single Roles tab and on the addition button at the top right corner.
Fill in the fields.
Single Role
: single role to be automatically assigned in a single role rule.Composite Role
for a composite role rule. -
Type
: assignment type that can be:Suggested
so that the role is listed among suggested permissions in the permission basket of users matching the criteria during an entitlement request, suggested assignments must be selected manually to be requested; orAutomatic
so that the role is automatically assigned to users matching the criteria; orAutomatic but with validation
so that the role is listed in the permission basket of new workers, these assignments can still be modified.The rule's type can be
Suggested
only if the related role is allowed to be requested manually. -
Single role denied
: option that forbids the assignment instead of applying it. -
Criteria: conditions that, if met, trigger the single role automatic assignment.
Role assignment rules can be based on identity dimensions. Moreover, single role rules can be based on composite roles.
Click on Create and see a line added on the rules page.
Impact of Modifications
Any modification in a role assignment rule is taken into account when the next Compute Role Model Task runs to compute new assignments. Therefore, if a given rule's criterion is modified, then all corresponding assignments are computed again. If a role was assigned automatically to an identity by a role assignment rule, and if this assignment doesn't comply with the new version of the rule, then the corresponding role is automatically removed.
A modification in a role assignment rule can trigger the removal of a role only on the Identity Manager side. There are several barriers to cross before said role is removed from the managed system.
For example, consider a single role rule that assigns the single role
Business role: electronic banking
to all users in theTours
department. Let's say that we replaceTours
withOrleans
. Then, after the next launch of the complete job, all users in theOrleans
department get said role, while the users in theTours
department are deprived of said role.
Perform a Simulation is available in order to anticipate the changes induced by a creation/modification/deletion in role assignment rules.
Netwrix Identity Manager (formerly Usercube) recommends removing redundant assignments after any assignment rule is created or updated.
Verify Rule Creation
In order to verify the process, start by checking the rule's details on the Access Rules page. Then, you can:
Select a test user in the directory, accessible from the home page.
Create a role assignment rule for a role that said user doesn't already have, and based on criteria which the selected user satisfies.
Trigger the computation of the role model through the complete job on the Job Execution page in the Administration section.
See the new permission in the user's View Permissions tab.
