Reconcile a Role
How to review non-conforming permissions, i.e. approve or decline the role suggestions made by Identity Manager after every synchronization. The aim is to handle the differences between the navigation values from the managed systems and those computed by Identity Manager according to the role catalog.
Non-conforming roles are considered as non-conforming assignments because no rule from Identity Manager's model can justify their actual assignment to an identity.
Role reconciliation with property reconciliation
For example, the AD hosts groups dedicated to various applications, and a role is assigned through group membership. An entitlement can be assigned to an identity by adding said identity's DN to the member property of the appropriate group. Identity Manager translates it by editing the identity's memberOf property with the new group.
In the case of the AD example, consider that we want to assign a specific role in SAP. Then, we find the corresponding group in the AD and add the identity's DN to its member property.
The result is a new item on the Role Reconciliation screen for said SAP role, plus an item on the Resource Reconciliation screen for the new memberOf property for said identity.
If the identity didn't have an AD account yet, then it is automatically created, and the item on the Resource Reconciliation screen displays also a modification of the accountExpires property.
  • If the role is reviewed (approved/declined), then the corresponding property is automatically reconciled accordingly.
  • If the property is reviewed (approved/declined), then the corresponding role is automatically reviewed too, its Entitlement Assignment workflow state transitioned to Manual (if approved) or Cancellation (if declined, then a deprovisioning order is sent).
So let's say we add Cedric Blanc to the list of members of the SAP groups SG_APP_SAP_1 and SG_APP_SAP_211. Then, after the next synchronization, Identity Manager displays one item for each role on the Role Reconciliation screen, and one item for all changes in the AD account on the Resource Reconciliation screen:
Example - Role Reconciliation
Example - Resource Reconciliation
Example - Resource Reconciliation - Properties
This operation should be performed in cooperation with managers who know their team's expected entitlements.
InputOutput
Provision (required)Complying roles
Review a Non-conforming Permission
Review a non-conforming permission by proceeding as follows:
  1. Ensure that the Compute Role Model Task was launched recently, through the complete job on the Job Execution page
    Home Page - Job Execution
    � Or through the connector's overview page, Jobs > Compute Role Model.
    Resource Type Jobs
  2. On the home page, click on the entity type that you want to manage in the Role Reconciliation section, to get to the non-conforming permissions page.
    Home Page - Role Reconciliation
    Role Reconciliation Page
    Each non-conforming permission can be commented by clicking on the corresponding icon.
    Comment Icon
  3. Choose one of the two possibilities to verify the permission:
    Contrary to resources, reviewed roles are then displayed on the Role Review page accessible from the home page, and can be reviewed again.
    • Either click on the approval icon to keep the non-conforming permission.
    Approval Icon
    • Or click on the decline icon to delete the non-conforming permission.
    Decline Icon
  4. Trigger provisioning by launching, on the appropriate connector's overview page, Jobs > Generate Provisioning Orders, then, after this first task is done, Jobs > Fulfill.
    Resource Type Jobs
Use bulk provisioning
Several roles can be reconciled simultaneously by clicking on Bulk Reconcile Roles.
Verify Role Reconciliation
In order to verify the process, check that the changes you ordered appear on the corresponding user's View Permissions tab.
View Permissions Tab
