Create and Assign Profiles
This guide shows how to create in the XML configuration profiles and the appropriate rules to assign these profiles automatically.
Create a Profile
Here is the xml configuration to create a profile in Identity Manager. See the Profile topic for additional information.
Code attributes enclosed with <> need to be replaced with a custom value before entering the script in the command line.
<Profile Identifier="User" DisplayName_L1="Basic User" DisplayName_L2="Utilisateur de base" />
Automatically Assign Profiles
To automatically assign profiles it is necessary to manipulate the ProfileRuleContext and ProfileRule. See the Access Control Rule and Profile Rule Context topics for additional information.
<ProfileRuleContext ResourceType="AD_Entry_NominativeUser" SubBinding="Directory_User:Records" IsAppliedToRoot="false">  <ProfileRule Profile="User" /></ProfileRuleContext>
Configure the Set InternalUserProfiles Task
The Identity Manager-Set-InternalUserProfiles task is mandatory to automatically assign the profile. The task can be selected from the Job provisioning list. See the Set Internal User Profiles Task topic for additional information.
<SetInternalUserProfilesTask Identifier="SetInternalUserProfiles" DisplayName_L1="Set Internal User Profiles" >    <TaskEntityType EntityType="Referentiel_User"/>    <TaskResourceType ResourceType="AD_Entry_NominativeUser"/>  </SetInternalUserProfilesTask>
Here the TaskEntityType is the reference to connect to Identity Manager and the ResourceType is the same as in the ProfileRuleContext. Once this configuration is done you can add the task in the job which provisions the Connector AD.
<Job Identifier="AD_Provisioning" DisplayName_L1="AD - Provisioning" DisplayName_L2="AD - Provisioning" Agent="Local">    ...
<SetInternalUserProfilesTask Identifier="SetInternalUserProfiles" DisplayName_L1="Set Internal User Profiles" >       <TaskEntityType EntityType="Referentiel_User"/>       <TaskResourceType ResourceType="AD_Entry_NominativeUser"/>    </SetInternalUserProfilesTask>  </Job>
