RSA Encryption
Identity Manager provides a few options to protect sensitive data via RSA encryption.
Sensitive data can be RSA encrypted by using Identity Manager's tools:
Usercube-Protect-X509JsonValue to encrypt given values;
Usercube-Protect-X509JsonFile to encrypt a whole file.
The file encryption tool should be used only on files that contain only plain text values, not already encrypted ones.
Once encrypted, sensitive values can be added to the appsettings.encrypted.json
and
appsettings.encrypted.agent.json
files. Identity Manager will read first the values from the
encrypted appsettings files, before reading those from the usual non-encrypted appsettings files.
These methods require an X.509 public key certificate (the same for the encrypted appsettings files and the tools).
The value encryption tool can be used to encrypt specific values to be added to the encrypted appsettings files without having to encrypt the whole files again.
Focus on the Encrypted Appsettings Files
The appsettings.encrypted.json
and appsettings.encrypted.agent.json
files contain respectively
the appsettings.json
and appsettings.agent.json
files' sensitive setting values which are
protected by RSA encryption.
These files follow the exact same structure as the Agent Configuration .
Read the Encrypted Files
Identity Manager can use an RSA decoding algorithm fed by a public-key certificate in order to read the encrypted application settings.
This requires the usual appsettings file(s) to have UseEncryptedAppsettings
set to true
. See
below.
appsettings.json and/or appsettings.agent.json
"EncryptionCertificate": {
"File": "./Usercube.pfx",
"Password": "secret",
"UseEncryptedAppsettings": true
This way, values from the encrypted file take priority over the values from the non-encrypted appsettings files.
For example, if
Password
exists in both the encrypted file and the non-encrypted file, then the value from the encrypted file is used.
