appsettings.agent
The appsettings.agent.json file is meant to contain configuration data to be used by the agent to run Identity Manager.
It includes:
  • Connections to the managed systems
  • Password reset settings
  • Connections to potential additional databases
  • OpenId information
  • Specific task configuration
JSON files can contain any additional information that you might find useful. See the example below.
For example, in order to store the agent's address, we can add:
Code attributes enclosed with <> need to be replaced with a custom value before entering the script in the command line.
appsettings.json
"UsercubeAgent": {
"Url": "<http://localhost:1234>"
As Identity Manager does not know any object named Identity ManagerAgent, its content will be ignored, but it can still be used to store information for human use.
Supported Sections
NameTypeDescription
Connections optionalList of ConnectionsConnection information of all the systems managed by this agent, for synchronization and fulfillment configuration. This section contains a subsection for each connection containing the connection's agent settings. Code attributes enclosed with <> need to be replaced with a custom value before entering the script in the command line. {   …   "Connections": {     …     "<ConnectionIdentifier>": {       "<AgentSetting>": "<Value>":       …     }   } } Example: {   …   "Connections": {     …     "Directory": {       "Path": "C:\UsercubeDemo\Sources\Directory.xlsx"     },     "ServiceNowExportFulfillment": {       "Server": "https://INSTANCE.service-now.com/api/now/table",       "Login": "LOGIN",       "Password": "PASSWORD"     }   } } See the Create a Connectionand Connection topics for additional information.
Databases optionalList of DatabasesNames and connection strings of all databases used by the agent through InvokeSqlCommandTask, other than Identity Manager's database and other than the databases provided in Identity Manager's available packages. This subsection contains a subsection for each additional database. NOTE: The Database is a subsection of the Connections section mentioned above. Code attributes enclosed with <> need to be replaced with a custom value before entering the script in the command line. {   …   "Databases": {     "<DatabaseName>": "<DatabaseConnectionString>"   } } Example: {   …   "Databases": {     "UsercubeContoso": "data source=.;Database=Usercube;Integrated Security=SSPI;Min Pool Size=10;encrypt=false;"   } }
OpenId optionalOpenIdOpenId information, i.e. the ClientIds and related ClientSecrets that the agent may use to authenticate to the server in order to launch jobs and tasks. In order to launch jobs and tasks, the profiles related to these OpenId credentials must possess the required permissions.
PasswordResetSettings optionalPasswordResetSettingsParameters which configure the reset password process for the managed systems that support it.
SourcesRootPaths optionalString ArrayList of folder paths from which Identity Manager is allowed to read. This option is used to validate the sources files defined in file-based connections. These paths are case sensitive. Code attributes enclosed with <> need to be replaced with a custom value before entering the script in the command line. {   …   "SourcesRootPaths": [ "C:/UsercubeContoso/SourceHR", "C:/UsercubeContoso/SourcesPhone" ]  }
TaskAgentConfiguration optionalTaskAgentConfigurationVarious settings to customize the behavior of some agent tasks.
OpenId
NameTypeDescription
AgentIdentifier requiredStringIdentifier of the agent, as it is named in the XML configuration. With the following configuration: Code attributes enclosed with <> need to be replaced with a custom value before entering the script in the command line. <Agent Identifier="MyAgent" DisplayName_L1="My Agent" URI="https://contoso.com" /> We could have the following setting in the agent's appsettings.agent.json: Code attributes enclosed with <> need to be replaced with a custom value before entering the script in the command line. {   …   "OpenId":{     …     "AgentIdentifier": "MyAgent"   } }
DefaultOpenIdClient requiredStringClientId that defines the default OpenId pair, from the OpenIdClients section, used by the agent to authenticate to the server. Code attributes enclosed with <> need to be replaced with a custom value before entering the script in the command line. {   …   "OpenId":{     "OpenIdClients": {       "Job": "secret1",       "Admin": "secret2",       "Agent": "secret3"     },     "DefaultOpenIdClient": "Agent"   } }
OpenIdClients requiredList of OpenIdClientsPairs of ClientIds and non-hashed ClientSecrets, to override the corresponding secrets specified in the XML configuration. Code attributes enclosed with <> need to be replaced with a custom value before entering the script in the command line. {   …   "OpenId":{     "OpenIdClients": {       "Job": "secret",       "Admin": "secret2"     }   } }
NameTypeDescription
EncryptionCertificate requiredEncryptionCertificateLocation of the public key certificate and the private key used to handle input and output files' encryption.
MailSettings optionalMailSettingsSettings for configuring the SMTP server, used to send password reset email notifications.
NotificationSettings optionalNotificationSettingsSettings to configure password reset notifications.
TokenBuildingSettings optionalTokenBuildingSettingsSettings to build the confirmation token used by the password reset's two-Way mode. The confirmation token is a base-64 encoded JSON Web Token (JWT) token that contains the information required to complete password reset when in two-way mode. It is appended to the confirmation Uri.
TwoFactorSettings optionalTwoFactorSettingsSettings to configure the password reset's two-way mode, i.e. the process where Identity Manager sends emails containing links to users for them to click on it and reset their passwords.
If you are using the certificate provided in the SDK, the agent will be unable to launch. You must create your own certificate.
Encryption certificate information can be set in one of two ways:
NameTypeDescription
File requiredStringPKCS #12 archive path on the agent's host file system. Code attributes enclosed with <> need to be replaced with a custom value before entering the script in the command line. {   …   "PasswordResetSettings": {     "File": "<C:/UsercubeAgentContoso/contoso.pfx>"   } }
Password optionalStringPKCS #12 archive password. Code attributes enclosed with <> need to be replaced with a custom value before entering the script in the command line. {   …   "PasswordResetSettings": {     "File": "<C:/UsercubeAgentContoso/contoso.pfx>",     "Password": "<oarjr6r9f00>"   } }
  • As a certificate from a Windows' certificate store identified by SubjectDistinguishedName or by Thumbprint. The Windows certificate also contains both the public key certificate and the private key.
NameTypeDescription
DistinguishedName Required if Thumbprint is emptyStringSubject distinguished name of the certificate. Code attributes enclosed with <> need to be replaced with a custom value before entering the script in the command line. {   …   "PasswordResetSettings": {     "DistinguishedName": "<UsercubeContoso>"     …   } }
StoreLocation requiredStringLocation of the relevant Windows certificate. Code attributes enclosed with <> need to be replaced with a custom value before entering the script in the command line. {   …   "PasswordResetSettings": {     …     "StoreLocation": "<LocalMachine>"   } }
StoreName requiredStringName of the relevant Windows certificate. Code attributes enclosed with <> need to be replaced with a custom value before entering the script in the command line. {   …   "PasswordResetSettings": {     …     "StoreName": "<AuthRoot>"   } }
Thumbprint Required if DistinguishedName is emptyStringThumbprint of the certificate. Code attributes enclosed with <> need to be replaced with a custom value before entering the script in the command line. {   …   "PasswordResetSettings": {     "Thumbprint": "<6261A70E599642A21A57A605A73B6D2AE7C5C450>"     …   } }
Remember, Netwrix recommends using Windows' certificate store.
On the other hand, the PFX file takes priority over Windows' certificate, which means that when File is specified then the PFX certificate is used, even if the options for Windows' certificate are specified too.
In both ways, missing and/or incorrect settings trigger an error and no certificate is loaded.
MailSettings
NameTypeDescription
FromAddress Required if PickupDirectory is emptyStringEmail address used by Identity Manager to send notifications. Code attributes enclosed with <> need to be replaced with a custom value before entering the script in the command line. {   …   "PasswordResetSettings": {     …     "MailSettings": {       "FromAddress": "<no-reply@acme.com>",       …     }   } }
Host Required if PickupDirectory is emptyStringSMTP server domain name or an IP address. To be used only when UseSpecifiedPickupDirectory is set to false.
Password RequiredStringPassword that Identity Manager will use to login to the SMTP server. used only when the SMTP server is password-protected and UseSpecifiedPickupDirectory is set to false.
PickupDirectory Required if FromAddress/Host are emptyPath to the pickup directory. See the Send Notifications topic for additional information. See more details on the pickup directory feature. To be used only when UseSpecifiedPickupDirectory is set to true. Code attributes enclosed with <> need to be replaced with a custom value before entering the script in the command line. {   …   "PasswordResetSettings": {     …     "MailSettings": {       "PickupDirectory": "<../Mails>",       …     }   } }
Username requiredStringUsername for Identity Manager to login to the SMTP server. Used only when the SMTP server is password-protected and UseSpecifiedPickupDirectory is set to false.
AllowedDomains optionalStringList of domains to which the SMTP server is authorized to send emails. Domain names must be separated by <;>.
CatchAllAddress optionalStringCatch-all address that will receive all of Identity Manager's emails instead of usual users. this is helpful for testing before going live. Code attributes enclosed with <> need to be replaced with a custom value before entering the script in the command line. {   …   "PasswordResetSettings": {     …     "MailSettings": {       "CatchAllAddress": "<administrator@acme.com>",       …     }   } }
CatchAllCCAddress optionalStringCatch-all address that will receive all of Identity Manager's emails as cc (carbon copied). Code attributes enclosed with <> need to be replaced with a custom value before entering the script in the command line. {   …   "PasswordResetSettings": {     …     "MailSettings": {       "CatchAllCCAddress": "<administratorcc@acme.com>",       …     }   } }
Enabled default value: TrueBooleanTrue to enable email sending. When set to false, no email is sent by Identity Manager.
EnableSsl default value: FalseBooleanDEPRECATED: EnableSsl won't be supported in the future. Please specify a SecureSocketOption instead. To keep the same behavior as EnableSsl: True, use the setting SecureSocketOption: StartTls. True to encrypt communication with the SMTP server. NOTE: To be used only when UseSpecifiedPickupDirectory is set to false.
SecureSocketOption default value: AutoStringSpecifies the encryption strategy to connect to the SMTP server. If set, this takes priority over EnableSsl. None: No SSL or TLS encryption should be used. Auto: Allow the mail service to decide which SSL or TLS options to use (default). If the server does not support SSL or TLS, then the connection will not be encrypted. SslOnConnect: The connection should use SSL or TLS encryption immediately. StartTls: Elevates the connection to use TLS encryption immediately after reading the greeting and capabilities of the server. If the server does not support the STARTTLS extension, then the connection will fail and a NotSupportedException will be thrown. StartTlsWhenAvailable: Elevates the connection to use TLS encryption immediately after reading the greeting and capabilities of the server, but only if the server supports the STARTTLS extension. NOTE: To be used only when UseSpecifiedPickupDirectory is set to false.
Port default value: 0StringSMTP server port. NOTE: To be used only when UseSpecifiedPickupDirectory is set to false.
UseDefaultCredentials default value: FalseBooleanTrue to use the default username/password pair to login to the SMTP server. When set to false, Windows authentication is used. NOTE: To be used only when UseSpecifiedPickupDirectory is set to false.
UseSpecifiedPickupDirectory default value: FalseBooleanTrue to write emails as local files in the specified PickupDirectory instead of sending them as SMTP packets. See the Send Notifications topic for additional information. Code attributes enclosed with <> need to be replaced with a custom value before entering the script in the command line. {   …   "PasswordResetSettings": {     …     "MailSettings": {       "UseSpecifiedPickupDirectory": true,       …     }   } }
NameTypeDescription
Cultures default value: ["en"]String ArrayList of languages in which reset-password email notifications will be sent, among: fr and en. Code attributes enclosed with <> need to be replaced with a custom value before entering the script in the command line. {   …   "PasswordResetSettings": {     …     "NotificationSettings": {       "Cultures": [“fr”, “en”]     }   } }
NameTypeDescription
ValidFor default value: 03:00:00StringValidity period of the issued token, and thus of the password reset link. The format must be HH:mm:ss Code attributes enclosed with <> need to be replaced with a custom value before entering the script in the command line. {   …   "PasswordResetSettings": {     …     "TokenBuildingSettings": {       "ValidFor": "<03:00:00>"     }   } }
TwoFactorSettings
NameTypeDescription
ApplicationUri requiredStringURI of the Identity Manager application. NOTE: this helps create the links in the emails for two-way password reset. Code attributes enclosed with <> need to be replaced with a custom value before entering the script in the command line. {     …     "PasswordResetSettings": {         …         "TwoFactorSettings": {            "ApplicationUri": "<http://localhost:5000>"            …         }     } }
ResetConfirmationUri requiredStringBase URI for the password reset link that is sent to the user. The password reset confirmation token is appended to the ResetConfirmationUri. The resulting URI is sent to the user. Code attributes enclosed with <> need to be replaced with a custom value before entering the script in the command line. {     …     "PasswordResetSettings": {         …         "TwoFactorSettings": {            …            "ResetConfirmationUri": "<http://localhost:5000/PasswordReset/Activate/?activationCode=>"         }     } }
NameTypeDescription
HttpClientTimeoutSupplement default value: 0IntegerAdditional minutes that extend the default timeout (30 minutes) of the HttpClient instance used to send requests to the server. Here the total timeout will be 50 minutes: Code attributes enclosed with <> need to be replaced with a custom value before entering the script in the command line. {   …   "TaskAgentConfiguration": {     …      "HttpClientAdditionalTimeout": 20   } }
