Usercube-Upgrade-ConfigurationVersion
This tool is used to upgrade your configuration from your current version entered in settings to the latest version.
Examples
./identitymanager-Upgrade-ConfigurationVersion.exe --version "5.1.0" --xml-path "C:/UsercubeDemo/Conf" --output "C:/UsercubeDemo/Conf2"
In this example, the configuration files are in the folder "C:/UsercubeDemo/Conf" and at version "5.1.0". This tools will upgrade all the xml files to the latest version and save them in the folder "C:/UsercubeDemo/Conf2".
Arguments
Argument Name | Details |
--version required | Type String Description Current version. |
--xml-path required | Type String Description Current xml configuration folder to migrate. |
--output required | Type String Description Path of the folder where the result will be saved. |
--log-level optional | Type LogLevel Description Level of log information among: Verbose ; Debug ; Information ; Warning ; Error ; Fatal . |
