Usercube-Protect-X509JsonFile
This tool is used to encrypt a JSON file containing sensitive connection data, for example the
appsettings-agent.json
file, with
RSA Encryption . The
encryption is based on the information given in your appsettings.json
file about either a PFX file
or the location of the encryption certificate in the Microsoft store. See the
Application Settings
topic for additional information.
This tool Usercube-Protect-X509JsonFile
is used to encrypt a whole file, in comparison to the
Usercube-Protect-X509JsonValue tool that encrypts only a
given value. This tool is more appropriate than Usercube-Protect-X509JsonValue
when you have many
lines to encrypt.
Examples
The command below encrypts the appsettings.agent.json
file from the C:/UsercubeTraining
folder
and creates the appsettings.encrypted.agent.json
file in the same folder.
./identitymanager-Protect-X509JsonFile.exe --input-json-file-path "C:/UsercubeTraining/appsettings.agent.json" --output-json-file-path "C:/UsercubeTraining/appsettings.encrypted.agent.json"
For example it takes this :
"TaskAgentConfiguration": {
"HttpClientTimeoutSupplement": 0
"OpenId": {
"OpenIdClients": {
"Job": "secret"
"DefaultOpenIdClient": "Job"
"PasswordResetSettings": {
"TwoFactorSettings": {
"ApplicationUri": "http://localhost:3000"
"NotificationSettings": {
"Cultures": [
"en"
And it returns this :
"HttpClientTimeoutSupplement": "kxABAEh6CpUOAOMBNPNLKazx9I0vqummv24acN292gonFiK4ov81bjqE2ic+n+HqastXU2aTQcl3IefhEXn9KA2dhnIbDTXB4GhOn9lL9AzUfwKXBr5EBmVy7ggruG2ewpWGK1c3LBJ35km9XvCnzSHLfolZwHNPwM/8b/C6XqSzieoFcO5H92IGJ1lFRboacvp0rO+SkkUv63Ewsk+1MrVLa63oBgWfY6PhMeJvNpWGqCD+I614hB6jE2Li/recwQIPd10XEgFM1OEkZ5ZiO+URxX7MCBe1o20rTaczKR7e7lLQGa/e3Y3i1sFnCm+yRm/lzw0qtDvOtCXlPT13EsHsUunxnR3uH4R6lRBXT30OKobaX7MTQjGkLRChss/GVGCK5w=="
"OpenId": {
"OpenIdClients": {
"Job": "kxABAOkh0BF2GdMedpzmKZZWVWc8IYaiZO2dofmt7lLBP3vMYgLLZYNDyR3x7Ah7tA1r6oSL5gBT3mSFyXB63NJk+QmZqNW1LWdzh+3U+DvNdQw4OfDfFlC5F+nH3/L5iqWc+h1jMlaQBpkqf42Vr8HwFKtqMXLJVXEIyeHSPgHRp1iOjGkNSRNrRQGJ4pVyo0xKmcWsz3qGYf0SnJIzRJ++PcYh/dJgxHAZFsDnV55X3zg72J8teoIEG82GdNjmCV/W4S4edNCYa1gL3KpgDGQq1GEed71Ht1tVYlHlJ4hckE++otQqTgRA2p4nFvo3LmlMag6k4EQRzEk6TOHUlGjUtYgpzMuPqei8/3CRXy5o8YW5R0wVFJJ/jSfYrvR3M9SwJw=="
"DefaultOpenIdClient": "kxABANLI/Qx7X8L1VtIl+FM4RtYlTLLpUUBCp2pucY+jzjlwhbF9fjJhhTP/KmeCj8M2yB4AA1V3AQgcEBvg92I1vCAWXIBgCjz6LUD2yf4FCpACaxNgiBZVAaCELNCgbKDgy9UB1j4sCozpEzReLVtYdOX+KFbGU6zJ808jnrLFMz+YHT4LXMyF94A5Zl86DFT9br6PwR75qImvjDlIUt+7/I8WrT1Nnqn2hXxqzAd1J2W5Xv8Bt9sXFmskSZN9PyOo9EY9t5lVGq++IqjGPWh4vQAXCzIsfRgUfU7PfHKVuSKSHbME1EZwG/FjzOe8B4bO2q/a/qLtGgygyX5ExEkZ/IcrtSZnTdqC83AfyexlEv9Z3wWFAoKGDtI3zhmCZYnuZQ=="
"ApplicationUri": "kxABAFAEx4fWwG/ANPVTf/WGyccDxoR2xCy+x+U3Ny1KkqnOFw+SizePTgINTzBaYHLTHABQD0GWW6U+4qiG6DpcIcdAD0VVnddqB5a+YIE0reufXYhZTrDU/9yeG6aUWIHkLl9UudC/nnW6zMrjChiJhJvT7csFKdgbqUazZT56hR0i6XS36a5h2/tTWhbZTkk1Dil5JP7xUcu5CMWyXMUvGvK8gfQozYxo/DJTOiLrWjg5ION1yx+ZqPhcIUxgYaBjxSpfT6U9YMy5mE9JGqf7W76baS9fOVr3H1DAL02icX29uJAcsw1r9k1rJQIKEhAuqTNeuqF6C6iPHJAsail+iteOJEYgBSACRz7Te4t6Hp7PBs0FfP0WY1oL+1T+p7X+HaO1jAJhE50J2AKhGNXTZfE="
"Cultures": [
"kxABAPwTbpFUbP9xT9HyqtTuMLKT9sVD0Qq1kCsI44d12vJEcW2MMy9K5vKakwTPeJpvY6SafELoHc7AjKnh8ZJi0/Yu4dieE5W+5uXY1uaghYJ/2VjimzIsDhvRhm90xUlaMjdFBjx4HAnxBAtEbEjifdGHxZ0L9F305hXSTORj53u76ctCE5D9HPTN3AgLmyIGv5NExwhD4sgppbf6PWjTEZ7yNcoUpkkS4pJ6BMz+PaQo26A2rMP710zQgG72an4XvxSoR3SwSm0fhLCASgYi8YOZw0j/cfxl/LrW1EQ7gyW0/Mw9v1YRNH3DkbWSeHZ3odhDWdaWkzR6yOEt5hO60eM0w8Tjoed30Jwf+enf1rJFStDe/dhg6vjUIaTn6tt1Gw=="
The previous command can be useful to encrypt, for example, an Active Directory's login used by the agent during the synchronization process.
The login to encrypt is stored in the following format, compliant with the appsettings.agent.json structure:
appsettings.beforeEncryption.json
"Connections": {
"ADExport": {
"Login": "Administrator"
This command writes encrypted values from appsettings.agent.json
to
following the
structure:
"Connections": {
"ADExport": {
"Login": "kxABAM9LW6vyx3TpDXoU5mKKQAwxxNcH9Q2z+dk+E7BNzrI346fUUiPmnJlOJZNX8bA1sokpDHTJBJngdF8LqVuWhk0t+IBpHE+iRJZ4q6i/CzX/OnpoGEHLSL5gZUixIqn9kul5AbxI38d/aGkCGIeAGY73rf0eQRizB2uR/ObR/H9jm3dHGt3TUNyOH4WqdwrXL0WTeMyfme6O+2PMoGvmjVF04keicuisjj/jROxTcDKe69qjPuCJZabR69CA2qP1TPMDMy/zlg8bzRZKepw8VxI4OpIKrbwhaUTauJMR6URPsOZ54fdocKi3oEyvpm2AhX4YF8GpOw7fBQrPWte/JJFOxgIzH1Kh0d0YhC2ZpMCXexfOlB2Y9afWG/t7rdi4VDsEf8gwj+IJ3HbE0dtIPLw="
Arguments
Name | Details |
--input-json-file-path required | Type String Description Path of the input to-be-encrypted json file. |
--output-json-file-path required | Type String Description Path of the output encrypted json file. |
