Usercube-Protect-CertificatePassword
This tool helps protecting .pfx
archives passwords. Given a plain text password, it generates an
encrypted version, that can be stored in a configuration file in place of the plain text one. The
tool uses a hard-coded secret RSA key to generate the encrypted password. Identity Manager uses the
same key to retrieve the plain text password and read the .pfx
archive.
Examples
Given a .pfx
archive protected by the secret
password, an encrypted version can be generated
with the following command:
./identitymanager-Protect-CertificatePassword.exe --pfx-password "secret"
The output is the following :
ep4BsLtg5RVFVI1kEIMZbV1q7Bg2eAFzeD73YX5fV7eklSIqcJcxHsCQbyY2zKLppXSX+Zpwm7xU5QY6DTAJleFbWsP/p0fjXUn1agy1tQ6l6t6wvURBZcePEgu+ivNjpUENbDIBotPdzbpISLJIjQbISzHDWnHuWPk/l8h0wXU=@WrAj9YdcNK8cQvfopZa5g1QFc1hk6nPolkwQAkU2ORfXupgV7kaWgKF4W/UmC0XXg4zuaqpVui6ivB0jbLTiXgQ62o+bG9ZSEJLaur4d20TMRNadqnWTWPWhVJF6XiS4jX7sDvVrZO3sKQJMNzZSeTKmsl0w0boCBEkuHsWDA24=@0oLLKxcTJGxSx1uGvhexEA==
This encrypted password can now be copied to the relevant location in a configuration file. For example :
appsettings.json
"EncryptionCertificate": {
"File": "C:/UsercubeAgentContoso/contoso.pfx",
"Password": "ep4BsLtg5RVFVI1kEIMZbV1q7Bg2eAFzeD73YX5fV7eklSIqcJcxHsCQbyY2zKLppXSX+Zpwm7xU5QY6DTAJleFbWsP/p0fjXUn1agy1tQ6l6t6wvURBZcePEgu+ivNjpUENbDIBotPdzbpISLJIjQbISzHDWnHuWPk/l8h0wXU=@WrAj9YdcNK8cQvfopZa5g1QFc1hk6nPolkwQAkU2ORfXupgV7kaWgKF4W/UmC0XXg4zuaqpVui6ivB0jbLTiXgQ62o+bG9ZSEJLaur4d20TMRNadqnWTWPWhVJF6XiS4jX7sDvVrZO3sKQJMNzZSeTKmsl0w0boCBEkuHsWDA24=@0oLLKxcTJGxSx1uGvhexEA=="
Arguments
Name | Details |
--pfx-password required | Type String Description Password of the .pfx archive's to encrypt. |
