Identity Manager-Manage-Configuration Dependent Indexes
This tool creates the necessary SQL indexes based on the latest deployed configuration to optimize certain queries performances.
Available optimizations:
  • Creates SQL indexes and statistics to optimize searches on specific entity types
  • Creates SQL indexes to optimize joins between records and main entity types
  • Creates SQL indexed views used to compute dashboard counters
Examples
./identitymanager-Manage-ConfigurationDependantIndexes.exe -e "Directory_User" -r "Directory_UserRecord" "Directory_Guest" -dc -s "data source=.;Database=Usercube;Integrated Security=SSPI;Min Pool Size=10;encrypt=false;" -a
./identitymanager-Manage-ConfigurationDependantIndexes.exe -auto -dc -s "data source=.;Database=Usercube;Integrated Security=SSPI;Min Pool Size=10;encrypt=false;" -a
## Arguments
| Argument Name | Details |
| --entityTypes (-e) optional | __Type__ String List __Description__ Sets the list of entity types for which optimization indexes will be created/updated. |
| --recordEntityTypes (-r) optional | __Type__ String List __Description__ Sets the list of record entity types for which optimization indexes will be created/updated. |
| --userProperties (-p) optional | __Type__ String List __Description__ Sets the list of User' properties that link the records and the users. (the order of the given userProperties' must match the order of the given recordEntityTypes'). |
| --dashboardCounter (-dc) optional | __Type__ No Value __Description__ Adjusts the indexed views for the dashboard counters appropriately. |
| --auto optional | __Type__ No Value __Description__ The entity types, record entity types and user properties are deduced automatically from the provisioning rules configured in the database. |
| --apply-to-database (-a) optional | __Type__ No Value __Description__ Directly applies the resulting SQL script to the database. |
| --database-connection-string required | __Type__ String __Description__ Connection string of the database. |
