Usercube-Export-Bacpac
This tool exports the database to a bacpac file, as a backup.
Examples
The following example generates to <C:/UsercubeDemo> a bacpac file from the Identity Manager database with the given connection string and based on the bacpac template from the SQL folder.
Code attributes enclosed with <> need to be replaced with a custom value before entering the script in the command line.
./identitymanager-Export-Bacpac.exe --database "<Usercube>" -s "<data source=.;Database=Usercube;Integrated Security=SSPI;Min Pool Size=10;encrypt=false;>" --bacpac-path 0 --template-bacpac-path "<C:/UsercubeDemo/SQL>"
Arguments
The list of arguments:
Argument NameTypeDescription
--database-connection-string (-s) requiredStringConnection string of the database.
--database requiredStringName of the database.
--template-bacpac-path requiredStringPath of the empty bacpac file or dacpac file containing the database schema. The database export tool includes a .dacpac file, <Usercube.SqlServer.dacpac>, in the Runtime folder and should be used as the value for this parameter. It can be generated manually by exporting an empty Identity Manager database.
--temp-bacpac-path optionalStringPath of the temporary folder storing the database's data.
--bacpac-path requiredStringPath of the generated bacpac file.
--without-history default value: falseBooleanTrue to exclude history data.
--without-job-instances default value: falseBooleanTrue to exclude job and task instances.
--without-workflow-instances default value: falseBooleanTrue to exclude workflow instances.
--without-campaign-instances default value: falseBooleanTrue to exclude access certification campaign items.
--without-temp default value: falseBooleanTrue to exclude the data of temporary tables.
--without-all default value: falseBooleanTrue to exclude history data, job and task instances, workflow instances and access certification campaign items. Remember, this option represents the usual use-case.
--log-level optionalLogLevelLevel of log information among: Verbose; Debug; Information; Warning; Error; Fatal.
