Usercube-Deploy Configuration
Retrieves all XML configuration files from a given folder, in order to calculate the configuration items to insert, update or delete in the application.
Examples
Locally
The following example deploys an on-premise configuration via a direct connection to the database through its connection string:
Code attributes enclosed with <> need to be replaced with a custom value before entering the script in the command line.
./identitymanager-Deploy-Configuration.exe -d "C:/identitymanager/Conf" --database-connection-string "data source=.;Database=Usercube;Integrated Security=SSPI;Min Pool Size=10;encrypt=false;"
Remotely
The following example deploys a SaaS configuration via an HTTP POST request to the server of the remote configuration:
./identitymanager-Deploy-Configuration.exe -d "C:/identitymanager/Conf" --api-url https://my_usercube_instance.com
RECOMMENDED: To be able to deploy a SaaS configuration, you must first provide your Identity Manager administrator with identity information. See the Identity Manager Deploy the Configuration topic for additional information.
Arguments
The table below displays the arguments for the Identity Manager configuration deployment.
Argument NameTypeDescription
--configuration-directory (-d) requiredStringPath to the configuration folder.
--continuous-deployment (-a) optionalNo ValueEnables automatic deployment when saving an XML file.
--deployment-slot optionalDeploymentSlotType of the targeted server among the slot names provided by Netwrix' SaaS team. For example: Development, Staging, Production. it is required when working in a SaaS production environment.
--dump-changes-directory optionalStringPath to a directory that will receive the logs of all modifications made to the database. Remember, it can be used with --simulate-only for an additional security before deploying to production.
--enable-saas-checks optionalNo ValueEnables the checks necessary to deploy in a SaaS environment. Remember, it is enabled automatically when working in SaaS. This argument can be used when deploying locally in order to anticipate a future SaaS deployment.
--force-bindings (-bi) optionalNo ValueForces the recomputation of binding paths in the database.
--force-cascade-delete optionalNo ValueEnables the deletion or archiving of XML configuration items that require extra care and/or approval, usually for dependency issues. Remember, Netwrix recommends using this option only when prompted by the deployment tool.
--force-categories (-c) optionalNo ValueForces the recomputation of the counters for role categories in the database.
--force-expressions (-e) optionalNo ValueForces the recomputation of C# expressions in the database.
--force-permissions (-p) optionalNo ValueForces the recomputation of access permissions in the database.
--force-translations optionalNo ValueForces the recomputation of the translations for the activity template states and the internal display name properties in the database.
--http-client-timeout-supplement optionalInt32Duration (in minutes) after which the deployment command times out, in addition to the default 30 minutes.
--no-create-index optionalNo ValueDisables the creation of indexes related to the configuration. Remember, Netwrix recommends using this option only when advised by the support team.
--reset-database optionalNo ValueDeletes the whole database and creates an empty one before deploying.
--resource-identity-property optionalStringOverrides the resource identity property used by the SelectUserByIdentityQueryHandler settings.
--simulate-only optionalNo ValueComputes and previews on the screen all the changes to be made, but without editing the database.
--api-client-id optionalStringLogin of the account authorized by Netwrix for configuration export/deployment in a SaaS environment. NOTE: It will be deprecated soon, rather contact the support team.
--api-secret optionalStringPassword of the account authorized by Netwrix for configuration export/deployment in a SaaS environment. NOTE: It will be deprecated soon, rather contact the support team.
--api-url optionalStringURL of the server to export/deploy the configuration to, for remote changes. Remember, it is required when --database-connection-string is not specified.
--database-connection-string optionalStringConnection string of the database. Remember, it is required when --api-url is not specified.
--product-translation optionalNo ValuePath of the JSON file that contains the application's translations. See the Import Product Translations into Identity Manager topic for more details on how to import the product's translations.
--log-level optionalLogLevelLevel of log information among: Verbose; Debug; Information; Warning; Error; Fatal.
