Usercube-Create-DatabaseViews
Generates entity model SQL views in the Identity Manager database. All views are prefixed by zz_
This tool deletes all views starting by zz_
and creates views from the entity model described in
the running configuration.
For every EntityType, a matching SQL view is created from the UR_Resource table.
Example
The following example allows the user to connect to Identity Manager server at
http://usercube.contoso.com
, using the ClientId Job
and Secret secret
, to generate views for
Identity Manager's database.
./identitymanager-Create-DatabaseViews.exe --api-secret secret --api-client-id Job --api-url "http://usercube.contoso.com" --log-level Debug
Arguments
Argument Name | Details |
--progress-use-database optional | Type String Description Update progress in the SQL database. |
--progress-use-database-child-instance optional | Type String Description Initiate child task instance. |
--progress-use-api optional | Type String Description Update progress with the API. |
--api-client-id required | Type String Description Login used to authenticate to the server. Every request from agent to server needs to be authenticated with an OpenIdClient Connect ClientId/Secret pair, linked to a profile with the relevant permissions. |
--api-secret required | Type String Description Password used to authenticate to the server. Every request from agent to server needs to be authenticated with an OpenIdClient Connect ClientId/Secret pair, linked to a profile with the relevant permissions. |
--api-url required | Type String Description URL of Identity Manager server. |
--log-level optional | Type LogLevel Description Level of log information among: Verbose ; Debug ; Information ; Warning ; Error ; Fatal . |
You can explore created views in the Identity Manager database's Views folder in SQL Server Management Studio
