Usercube-Configuration-Transform
This tool applies a series of transformations specified in a JSON file, on the content of a given directory.
Example
The following example searches all occurrences of Directory_User
in the files inside
C:/UsercubeDemo/Conf
whose names:
- contain
guest
to replace all occurrences withDirectory_Guest
; - contain
bot
to replace all occurrences withDirectory_Bot
The resulting files are saved in C:/UsercubeDemo/ConfTransformed
./identitymanager-Configuration-Transform.exe --input "C:/UsercubeDemo/Conf" --output "C:/UsercubeDemo/ConfTransformed" --transformation-file "C:/UsercubeDemo/transformations.json"
"*guest*": {
"Directory_User": "Directory_Guest"
"*bot*": {
"Directory_User": "Directory_Bot"
Arguments
Argument Name | Details |
--input required | Type String Description Path of the directory on which the transformations are to be applied. |
--transformation-file required | Type String Description Path of the JSON file that contains the transformations to be applied. The first half of the following JSON transformation file intends to search all files in the input directory whose names are filename (case-insensitively). In those files, any occurrence of ToBeReplaced (case-sensitively) is replaced with Replacement . \{ "filename": \{ "ToBeReplaced": "Replacement" \}, "partialfilename*": \{ "ToBeReplaced2": "Replacement2" \} \} Note: instead of a specific file name, Identity Manager can search for files whose names contain a specific string, using the character * . |
--output required | Type String Description Path of the folder where the result will be saved. |
