EasyVista
This connector exports and fulfills users from/to an EasyVista-compliant system.
This page is about EasyVista .
Package: ITSM/EasyVista
EasyVista is an IT Service Manager that provides a service to organize IT resources in a company by using tickets. This allows users to manage projects, materials and teams through a customizable interface.
Prerequisites
  • Reading first the appsettings.agent topic;
  • An EasyVista account with reading/writing permissions on the target instance;
  • A view to be created in EasyVista for each type of entity to export.
Export
This connector exports a list of users, with their attributes specified in the connector's configuration, to CSV files.
It can also export any custom entity, provided that a view exists for it in EasyVista.
Configuration
This process is configured through a Connection in the UI and/or the XML configuration, and in the appsettings.agent.json > Connections section:
"Connections": {
"<ConnectionIdentifier>": {
  • be unique.
  • not begin with a digit.
For example:
"Connections": {
"ExportEasyVista": {
"Server": "https://easy-vista.instance.com/",
"Account": "11111",
"Login": "username",
"Password": "userPassword",
"ExportSettingsOptions": {
"Profiles": "https://easy-vista.instance.com/api/v1/11111/internalqueries?queryguid={019B0523-F1C4-4G84-AA04-47BA16F16EB2}&filterguid={Z8A61D04-EZEC-42F1-A3E1-E9E09654BE68}&viewguid={2740V37A-A0ZC-4E50-A1F1-CF0987B9EFEA}"
The ExportSettingsOptions attribute is necessary only if custom entities are exported. It is not required if only the users are exported.
Besides, "Profiles" is used here as an example and corresponds to a name to identify the exported entities.
Setting attributes
NameDetails
Server requiredType String Description URI of the server to connect to.
Account requiredType String Description Account to use to connect to the EasyVista instance.
Login requiredType String Description Username to use to connect to the EasyVista instance.
Password requiredType String Description Password to use to connect to the EasyVista instance.
ExportSettingsOptions optionalType List Description List of entities to retrieve from the EasyVista instance. Note: for any customized entity to be exported, this argument must contain its REST API URL. Get REST API URLs Access the relevant view in EasyVista and click on ... > Rest API Url to copy the URL. For example: EasyVista Profiles View
Output details
This connector is meant to generate to the Application Settings export output folder:
  • a CSV file, named <connectionIdentifier>_Employees.csv, with one column for each property having a ConnectionColumn and each property without it but used in an entity association;
  • a CSV file for each customized entity, named <connectionIdentifier>_<EntityName>.csv.
For example, with the following entity type mapping for employees:
<EntityType Identifier="EasyVista_User" DisplayName_L1="EasyVista User"> <Property Identifier="lastName" DisplayName_L1="lastName" TargetColumnIndex="0" Type="String" /></EntityType><EntityTypeMapping Identifier="EasyVista_User" Connector="ExportEasyVista" ConnectionTable="EasyVistaExport_Employees"> <Property Identifier="lastName" ConnectionColumn="last_name" /></EntityTypeMapping>
And the following entity type mapping for profiles:
EntityType Identifier="EasyVista_Profiles" DisplayName_L1="EasyVista Profiles" Property Identifier="NAME_EN" DisplayName_L1="NAME_EN" TargetColumnIndex="23" Type="String" Type="String" IsKey="true" //EntityTypeEntityTypeMapping Identifier="EVProfiles" Connector="ExportEasyVista" ConnectionTable="EasyVistaExport_Profiles" Property Identifier="PROFILE_GUID">>>> ><<<<<<ConnectionColumn="PROFILE_GUID" IsPrimaryKey="true" / Property Identifier="NAME_EN" ConnectionColumn="NAME_EN" IsPrimaryKey="true" /></EntityTypeMapping>
Then we will have C:/UsercubeContoso/Sources/EasyVistaExport_Employees.csv as follows:
last_name
Talma Bart
Tanner Carol
Taverner David
Taylor Eric
Telemann Franck
Thomson Georges
Then we will have C:/UsercubeContoso/Sources/EasyVistaExport_Profiles.csv as follows:
NAME_EN, PROFILE_GUID
Administration {value of the PROFILE_GUID}
LOB Manager {value of the PROFILE_GUID}
Product Team {value of the PROFILE_GUID}
Project Manager {value of the PROFILE_GUID}
Users created from the API are retrieved by Identity Manager only after a complete synchronization.
Fulfill
The EasyVista connector writes to EasyVista to create, archive (delete from Identity Manager's point of view) and update employees, initiated manually through the UI or automatically by Evaluate Policy
Configuration
For example:
"Connections": {
"FulfillEasyVista": {
"Account": "11111",
Setting attributes
NameDetails
Output details
This connector can:
  • Create and update employees and their profiles, but is limited by API limitations;
    In particular, this connector cannot set dates nor the employee_id property.
  • Archive employees, i.e. set the CONTRACT_END_DATE to the date of the fulfill execution.
    This action is performed when Identity Manager fulfills a provisioning order with a Deleted change type.
Authentication
Password reset
See the appsettings.agent topic to find out more on how to configure password reset settings.
Credential protection
